How do you get the choppy idle?????
Old Jan 3, 2012 | 06:25 AM
  #31
getsideways's Avatar
Originally Posted by Dynotech Tuning
Lol, 90% of the evo's I've driven are rocking' an Exedy Twin. I honestly think an Exedy twin is far easier to drive than a heavy 2600lb single disc.
-Jamie
Exedy twins arent bad, Its the tiltons and quartermasters (or any 7.25 clutch) of the world that are a pita. Having big cams in my 8 made it sound so awesome sitting there but like i said before DD suffured and it didnt seem that bad until you hopped in another evo that didnt have huge cams.
Old Jan 3, 2012 | 07:35 AM
  #32
Dynotech Tuning's Avatar
Yeah, one of our evo's has a Tilton triple. That's like an on/off switch with nothing in between.
-Jamie
Old Jan 3, 2012 | 08:05 AM
  #33
Vivid Racing's Avatar
Yeah, unstable idle results in unreliable take-off's. It generally requires a quick blip of the gas before starting from a stop. If you take off during one of the lower RPM lopes, it may want to stall and make you look like a silly noob.
-Jamie
Too much throttle blipping will make you look like a silly ricer, though. Got get it juuuust right!
Old Jan 3, 2012 | 09:14 AM
  #34
Mauricio Evo IV's Avatar
I´m not an expert in this area. Before I was hks 272/264 in my evo whit a good idle 15.4 AFR and a very nice choppy sound!!! Right now with my kelford cams 272, the car doesn´t sound good for me. the idle is in 13.4-7 (I change injectors from 560cc to 1,000cc) The cars runs great but I don´t like the sound in idle, sounds normal ... What can I do??
I have an Evo 8 ecu in my car (Evo 4), so I need change what for a choppy sound??
Old Jan 3, 2012 | 09:15 AM
  #35
lol, true. You gotta be professional blipper haha.
-Jamie
Old Jan 3, 2012 | 09:17 AM
  #36
Leaner AFR and/or lower ignition timing. Cam gear adjustments can do it too.
-Jamie
Old Jan 3, 2012 | 09:21 AM
  #37
-Jamie
Ok thanx a lot!!! I only need adjust the low octane fuel map right ????
I dont have cam gear adjusments
Can you help me only to change those numbers in my map????
Old Jan 3, 2012 | 09:38 AM
  #38
evo8 951's Avatar
I'd be greatful for a smooth idle. My **** idles to damn hard at times and it gets annoying none the least.
Old Jan 3, 2012 | 09:50 AM
  #39
Mobrown's Avatar
Originally Posted by Prolifik
jesus!! i got the same cams and sound no where near this. what did you!!!
Old Jan 3, 2012 | 09:54 AM
  #40
Raptord's Avatar
You need to make changes in the high octane map, not low octane.
Old Jan 3, 2012 | 10:33 AM
  #41
Are your cam gears set to zero or are they degree'd?
Old Jan 3, 2012 | 11:40 AM
  #42
So, I need an expert for that, because that change my tune right?
Old Jan 3, 2012 | 12:37 PM
  #43
Raptord's Avatar
Not really, just remove timing in the 0-1000rpm, 0-40 load area. Don't go below 5°
Last edited by Raptord; Jan 6, 2012 at 08:58 PM. Reason: Accidentaly said to add timing rather than remove it
Old Jan 3, 2012 | 02:31 PM
  #44
Not really, just add timing in the 0-1000rpm, 0-40 load area.
thank you very much sir!!!!!!
Old Jan 6, 2012 | 11:47 AM
  #45
excuseme, how much timing???
mine in that table is in 8*... is ok in 12*???
