Tune to safe wot after cam install help!!!
here is the current fuel map im going to try to get pulls with if I shouldnt someone pls let me know, i wont be able to do my pulls till either lunch time or until after work again any advice is greatly appreciated
@ 211ratsbud can you pls elaborate a lil on this if possible to make sure i grasp the concept?
thnx for the advice raptord trimming the fuel map, now will post up another one on my lunch
thanks for all the help guys really appreciate it
If one of the guru's has a better way to explain or elaborate on what Im trying to hint at then please do.. Also Raptord noted that youre pretty rich in that area, its hard to see yourself driving in those areas because you normally do pulls going WOT from a given RPM. So those areas kind of get jumped over really fast some times. I brake boost in a low gear to 5- 10 psi paying careful attention to keep the boost consistent the whole way up the RPM.
sup guys so im gonna hold off on the tuning gonna get a boost leak tester and a o2 housing then im gonna try again... question my load is going up to 270's would that mean im pushing around the neighborhood of 27psi correct? and if so can that much of boost be ran on 92 oct safely at that level or should i bring it down to around 25, that is what it was prior to the cam install and 4"i/c
Hey guys update on my learning attempt of tuning lol here are my fuel map, timing map and some log pulls im kinda stumped it idle both high about 2k until it warms up idk y?. then it drives like cr@p at slow speeds if i dont let it warm up im gonna post up some pics of maps and hopefully someone can help me out. How do you tune the 1 n 2nd gear area cuz at times itll go rich. the person who tuned my car also turned off lean spool is this a advantage or disadvantage? I know this is a lot of questions so im gonna be patient
hopefully they all get answered
is there any room for more timing with my new S2's? i added one degree in the higher rpms, but now looking at a prior cam install timing map and after i think the problem could prob be in the maps due to me rescaling pls lmk... thanks for any help I may get in advance
more pics this shows my low coolant temp timing map idk if this will help but maybe lol also added the pre cam timing map
First off I think your WOT timing is too low; something like 2 degrees at peak load going up to 9-11 at 7000 would make more sense.
You're ok with lean spool disabled.
