nlts question
Old Apr 8, 2012 | 07:54 PM
01sporty's Avatar
nlts question
okay I am pretty new to the evo stuff but I have setup nlts on multiple dsms. My question is I have looked at the ecu pinouts that are for my 2003 evo 8. i have tephra v7 in it now I have a clutch switch in.
do I wire into pin 88 which road race pinout diagram shows it is cam sensor??? just asking to make sure I don't eff anything up.
Also my ecu has 4 plugs??? everywhere I search everyone talks about 3 plug ecus
thanks in advance
Old Apr 8, 2012 | 08:53 PM
Murf's Avatar
Okay you have tephra mod rom. Now did you need to reinstall the clutch switch? As for using nlts it activated in the rom using Ecu flash. Then set the parameters you want it work at. Reflash car with changes, test it out.
Old Apr 8, 2012 | 09:47 PM
01sporty's Avatar
2003 evo 8 didn't have a top clutch switch. I installed one and grounded one terminal what I am asking is what pin to ecu is it 88 for sure?? That is my question. I just don't want to ground out the wrong terminal lol
Old Apr 8, 2012 | 10:18 PM
Murf's Avatar
Not true on the clutch switch. Someone removed it for some unknown reason (might of had a remote start ) If its wired back in correct then you just need to activate it in the rom. By wired back in right I mean like the wiring diagram from the factory has it.
Old Apr 8, 2012 | 10:29 PM
HyperDisorder's Avatar
You're after pin 43 for 4 plug ECU's:
http://evoecu.logic.net/wiki/USDM_VIII_ECU_Pinout
Pin 88 should already be wired up on your ECU.
Old Apr 8, 2012 | 10:30 PM
01sporty's Avatar
Really?!! I was told it didn't have one Grrrrr does anybody have a pinout out then or a wiring diagram
Old Apr 8, 2012 | 10:33 PM
01sporty's Avatar
We are talking about a sensor on the top right not the the bottom switch for starter engagement
Old Apr 8, 2012 | 10:36 PM
01sporty's Avatar
Also one more question so does the top and bottom clutch sensor share a pin in the ecu then?? I tried tracing wires but it got dark so I called it a night
Old Apr 8, 2012 | 10:37 PM
01sporty's Avatar
Thanks for the info
Old Apr 8, 2012 | 10:42 PM
01sporty's Avatar
Took one last look and wa la found them!!!! Someone cut them and wired them to a wire that does nothing
seankhan
Australian Forum
May 18, 2017 12:30 AM
TJung
Sep 8, 2015 09:57 PM
3VOLUTIONIST
May 24, 2015 06:47 AM
GraphanaticIXSE
Dec 28, 2006 07:09 AM
Miralution
Sep 24, 2006 06:58 PM
