Help configuring ecuflash & evoscan
Old Apr 11, 2012 | 09:33 AM
Buguy's Avatar
Hey guys I need some help configuring and "setting up" ecuflash with evoscan.
I don't really grasp the concept of the mut table but my numbers for 1byte load and 2byte load don't match up with my mut table chart in ecuflash, atleast i dont think so. Can someone explain to me how to match everything up and make sure everything is working and logging\reading properly?
Thanks,
Pat
Old Apr 11, 2012 | 12:06 PM
Boosted Tuning's Avatar
Email me your ROM, your EvoScan data settings file and a couple of logs and Ill check it out for ya.
My email addy is in my sig.
Old Apr 11, 2012 | 12:31 PM
canberkd's Avatar
I also have a problem related with my evoscan.
As i am logging my aem wideband with evoscan, the values shows as 147 or 134 etc..
where values should be like 14.7 or 13.4... What could be the problem ? I didnt make any changes over the wideband equation, its function at evoscan is just x.
Old Apr 11, 2012 | 12:44 PM
There is a function to use for the AEM wideband.
Read here for more info. https://www.evolutionm.net/forums/ec...-function.html
Old Apr 11, 2012 | 12:49 PM
canberkd's Avatar
the thing is i am logging over a usb to serialport cable. I didnt wire my wideband to ecu. The values are correct but only " . " is missing ?
Old Apr 11, 2012 | 01:02 PM
Well then, a simple equation of "x/10" should do the trick.
Old Apr 11, 2012 | 01:11 PM
canberkd's Avatar
will try that and feedback here. Thank you
Old Apr 12, 2012 | 12:32 PM
Buguy's Avatar
Jay I'm trying to get you those things but when i try to "read from ecu" in ecu flash i get the no response to any given code error. :/
-Pat
Old Apr 13, 2012 | 12:18 AM
msgofast's Avatar
I am stuck trying to get the evoscan to talk to the ecu, can flash with openecu all ok, but get nothing trying to log, test outputs and evoscan sees cable, but not the ecu?
any help please?
thanks.
Old Apr 15, 2012 | 10:01 AM
canberkd's Avatar
That equation did change nothing
Attached Thumbnails Help configuring ecuflash & evoscan-evoscanwidebandporblem.jpg
Old Apr 15, 2012 | 11:06 AM
Ahh I think I see yoru issue. Your international right? And the language your computer is set to uses "," instead of "." for decimal points right?
If the answer to those questions is yes, then I think that may have something to do with your issue.
But I could be wrong.
Jack_of_Trades
May 29, 2018 07:05 AM
neuralcj
Jan 7, 2018 02:50 PM
Cbr1000love
Jan 31, 2016 05:01 PM
Danieln
Apr 15, 2010 05:04 AM
EvolutinIX
Apr 1, 2010 05:48 PM
