Need help: tephra mods on Evo 7 with 99860002
Old Apr 23, 2012 | 11:14 AM
TJung's Avatar
Hello. I've bought my another Evo. It's EU Lancer Evo 7 which has rom id 99860002. I would like to implement few mods, like NLTS, Stat Rev limiter (it doesn't have it), or valet mode. I know that are some rom's for Evo 7 with tephra mod, but I am not sure, if I can use them with my ecu ?
I found these files with Tephramod: http://www.geekmapped.com/forums/showthread.php?t=22 and this: http://www.geekmapped.com/forums/showthread.php?t=2105
Can I use them instead of my rom ?
Thanks
Old Apr 23, 2012 | 11:51 AM
SkyNight's Avatar
You can use 90550701.
Old Apr 23, 2012 | 09:03 PM
TJung's Avatar
Thanks ! Which tables should I copy from my rom?
for sure fuel/timing/boost/idle, but what about MUT tables, knock filtering etc ?
Old Apr 24, 2012 | 09:28 PM
awdordie's Avatar
you should copy every single table or at least compare to be sure they are the same. after you do this a few times you will become faster. first few times will take a while to copy every table but it must be done.
Old Apr 25, 2012 | 11:28 AM
TJung's Avatar
I am asking about MUT tables and knock filter tables, becuase they are not looking the same. I suppose I should rescale them ?
Old Apr 25, 2012 | 12:50 PM
todd6027's Avatar
leave those alone also the fuel and timing tables might be scaled differently (higher) use 90550001 or the v7 equivalent the 96530706 rom doesnt work very well on most 7s
Old Apr 25, 2012 | 09:35 PM
TJung's Avatar
Doesn't?
Old Apr 27, 2012 | 06:52 AM
todd6027's Avatar
Doesn't?
nope its an evo 8 rom , use 90550001 or 90550701
pqek666
Aug 9, 2024 11:55 AM
ug_orf
Feb 19, 2016 09:26 AM
GeoMitsu
Nov 3, 2013 08:58 AM
turbodailydan
Jul 6, 2013 11:55 PM
MR Turco
Sep 21, 2009 05:12 AM
