Stock injector battery voltage latency not right?
Old Apr 30, 2012 | 01:02 AM
csra09's Avatar
I need help with trying to figure out why injector battery voltage latency table shows these numbers for stock injectors? Also it will not let me adjust ms. Scaling is stock 532.
volts - ms
4.69 3.825
7.03 3.27
9.38 1.695
11.73 1.11
14.07 0.809
16.42 0.57
18.69 0.405
09 Ralliart - 53600010
<table name="Fuel Injector Scaling" address="536cc" category="Fuel" type="1D" scaling="InjectorScaling"/>
<table name="Injector Battery Voltage Latency Compensation" address="556d0" category="Fuel" type="2D" scaling="InjectorLatency">
<table name="Battery Voltage" address="60eb2" type="Y Axis" elements="7" scaling="BatteryVoltage"/>
</table>
<table name="Injector Base Latency" address="53000" category="Fuel" type="1D" scaling="InjectorLatency"/>
Any help is appreciated.
Old Apr 30, 2012 | 02:35 AM
richardjh's Avatar
Can you please explain why those values are not as expected?
Cheers,
Rich
Old Apr 30, 2012 | 07:48 AM
Golden's Avatar
They look stock to me.
Old Apr 30, 2012 | 10:27 AM
csra09's Avatar
Thanks. Long day and rookie mistake. Still learning figured better to ask. After comparison to a stock evo rom the numbers were different. Searching a older thread comparing tables showed they had the same injector voltage latency in stock form...kinda confused me. Well time to do some more research/reading.
Old Apr 30, 2012 | 02:31 PM
fostytou's Avatar
EvoM Community Team
The base scaling changed at some point: https://www.evolutionm.net/forums/ev...hm-change.html
....so it may be because of that. You shouldn't visually compare, just open up the other rom in the same version of ecuflash.
Boosted Tuning
Aug 26, 2023 10:14 PM
mrfred
Oct 13, 2020 10:33 PM
GP148
Feb 11, 2016 02:59 PM
mrfred
Oct 2, 2015 12:41 AM
EvocentriK
Jan 22, 2012 03:33 PM
