Evoscan data edit
Old May 1, 2012 | 12:46 PM
fabiangt79's Avatar
Evoscan data edit
Does anyone know how i can change the units in the evoscan data?
For example, if i want to read the boost in BAR instead of PSIg?
How do i add data that i want to log?I know that can just click to add but not sure where and how to get the correct data to key in and log accurately?
Old May 1, 2012 | 04:11 PM
07EvoIX's Avatar
in evoscan, right click where the data elements are. then select Edit.
From there you can either edit existing data elements or add new ones.
to change a data elements output, you will need to know the formula for that element which is based on the MAP sensor you are using.
cheers
Old May 2, 2012 | 03:11 AM
fabiangt79's Avatar
cheers
Let's say I want to change the manifold absolute pressure units to log as bar, where can I get the formula from?
Still a newbie on using this evoscan, can someone patiently advise or guide me thru it.
Thanks
Old May 2, 2012 | 09:53 AM
evo8426's Avatar
Thanks
This should work for you
Change the formula from " 0.19348 " to " 0.01334 " and you probably will have to subtract " 1 " instead of " 14.7 "
Old May 3, 2012 | 08:42 AM
fabiangt79's Avatar
Hi,
Sorry really noob on this, you are saying change the EVAL?
Can guide me clearly?Appreciate your help, thanks.
Could this be the reason that the max unit is reached as when i log full load it disconnects?
My max boost units measure is 100 as default.
Old May 3, 2012 | 04:51 PM
evo8426's Avatar
Actually I just noticed that Evoscan has a setting where you can change from Imperial Units to Metric Units. It is in the "Logging" tab at the top of the screen, then you need to look near the bottom of the list and click on "Metric Units" this should actually change it for you without having to edit anything.
Old May 6, 2012 | 09:51 AM
fabiangt79's Avatar
I have tried to change in the logging tab but still unable to log as bar for boost
mrfred
Sep 14, 2022 07:08 PM
3VOLUTIONIST
May 13, 2017 01:12 AM
mrfred
Dec 7, 2015 01:49 PM
mrfred
Dec 2, 2009 02:00 PM
mrfred
May 7, 2009 06:24 PM
