Strange ZT3 WB AFR Readings?
Old Jun 30, 2012 | 03:00 PM
CDrinkH2O's Avatar
Question Strange ZT3 WB AFR Readings?
Hi guys - i need some advice on how to trouble shoot a problem with my zeitronix ZT-3 set up. I installed it 9 months ago in a bung at the end of the DP just before the cat. Its mounted at the 10 o'clock position about 36 inches from the turbo. It's running the Bosch LSU 4.2 sensor. It is wired directly to the ECU and I have the red LED guage mounted in the clock on the dash.
Recently I noticed that the LED guage will occasionally jump to 14.7, and remain rock steady at that value for about 30 seconds, before dropping back to the normal changing AFRs. This corresponds with the steady WBO2 reading of 14.7 that I'm logging in Evoscan 2.9. It does this randomly throughout the operating range at varying loads and RPM. I've noticed that this is starting to happen more frequently. It used to be just once per drive and now it is 3 or 4 times per hour. This seems to indicate that something is gradually degrading either in the ECU, the zeitronix software, the wiring, or in the sensor itself.
The first thing I did to begin to trouble shoot this strange reading was to disable closed loop in the Tephra V.7 96530706 ROM I'm running. Periphery FAA bit 4 is set to zero. I run most of the time in open loop for economy cruise on E85 so my AFR map is already tuned for this. This has prevented the ECU from going in to closed loop at low load and TPS readings, and it now stays in open loop all the time. I'm still seeing the random 14.7 AFR readings logged in Evoscan
I don't feel the engine and ECU is suddenly going closed loop on me so I believe this may be a sensor problem. I guess this narrows the source of the weird readings down to the Bosch sensor, the wiring or the zeitronix software. How should I go about narrowing it down to root cause?
Old Jun 30, 2012 | 04:31 PM
todd6027's Avatar
try re calibrating the sensor
Old Jun 30, 2012 | 05:03 PM
Raptord's Avatar
Zeitronix sensors don't need to be calibrated.
Old Jun 30, 2012 | 06:54 PM
CDrinkH2O's Avatar
Any suggestions on how to trouble shoot this guys?.........
How do wide band sensors normally fail? This is a bosch LSU 4.2. The ZT-3 unit converts it to 0V - 5V linear output. 0V = 9.6 AFR and 5V = 21.6 AFR. It seems strange that it would fail intermittently in the middle of the range..no?
Old Jul 1, 2012 | 04:40 AM
killerpenguin21's Avatar
i would just grab a new sensor. i have had 3 sensors fail (i have a bad mounting angle) and only 1 has failed the way everything says it will fail.
the lsu 4.2 can be had for 50 bucks at autozone if you dont mind the plug not matching (factory sensor for a lot of vw's and such)
Old Jul 1, 2012 | 08:50 AM
CDrinkH2O's Avatar
Thanks for the feedback and suggestion killerp. I'll go and buy a new LSU 4.2 once I've talked to Zeitronix on Monday. Indicating stoich exactly could also be a problem with the ZT-3 control unit which sits between WB and ECU. Will post up results once I figure this out.
Old Jul 1, 2012 | 11:04 AM
todd6027's Avatar
its a bosch sensor
Old Jul 1, 2012 | 08:03 PM
from my notebook, just fyi.
bosch lsu 4.2 found in vw 1.8T bosch part numbers:
0 258 007 057,
0 258 007 058
difference in part numbers should just be wire length.
Old Aug 23, 2012 | 10:54 PM
CDrinkH2O's Avatar
It was the sensor. Once I replaced with a new one everything works the way it should - case closed.
dr_latino999
10
Jan 22, 2016 05:37 PM
TTP Engineering
May 22, 2009 09:52 PM
TTP Engineering
62
Apr 24, 2009 03:26 PM
BarryC
For Sale - Miscellaneous Automotive
Jun 17, 2008 02:36 PM
500whp.com
40
May 18, 2006 10:29 AM
