What sd iat method to use for more consistent fueling?
Ok so I used the hair dryer to test my 03 which reads the gmiat. Got her up to 200 degrees. There must have been some confusion because I thought fuel temp was 03 by default and to convert mat > iat you entered 0e. So I'll be giving this a shot turns out I could have had something totally set up wrong
Sigh..
Sigh..
Are you saying that if you use the fuel temp sensor, then you need to change the scaling? Any changes need to be made to use the GM IAT? Where?
Yeah I tried using 03 but car loses power. It runs better on oe. I have an iat installed .What do I change my maf air compensation to to make this work.I have 2150's also.Not fully understanding what I am doing wrong,help. By the way I am using rom 94170715
crudman
19
Jun 16, 2015 08:59 PM
