Need some input
Old Jul 28, 2012 | 08:30 PM
Capone24's Avatar
Need some input
So i installed a brand new AEM UEGO wideband about 2 months ago on my Evo9 MR. Since the day i installed it my AFR at idle always read 16-18, at the time i figured it was the tune and didnt pay much attention to it because of that and since it was only at idle and not WOT. This was on stock inj w/ walbro 255 and just a quick little reflash tune btw.
Fast forward today as im trying to get tuned by Tom aka TSCOMPUSA (whos been nothing but overly helpful on helping me diagnose the problem) i noticed that even on perfectly stoich fuel trims at idle, my wideband is still reading lean in the 16-18 range. Another sympton iv noticed is that now after installing the 1250cc inj when the car idles lean (like it always has since the wideband was put on) it now idles rough and is jerky sometimes part throttle. I know its not the tune since my trims are good and front o2 feedback is good aswell, so that leaves me to think that something is causing my wideband to show lean AFR (when its really not) which in return gives me rough idle while idling.
What do you guys think the problem could be? Boost leak, Exhaust leak, Vaccum leak, something fuel related? All help is appreciated, Thank
P.S. sorry for the long paragraphs lol
Old Jul 29, 2012 | 02:38 AM
charlie.tunah's Avatar
Probably exhaust leak. My o2 housing - DP leaks, radiator has a black spot and mine does the same thing. Makes Open Loop idle tuning "fun". It seems that anything above idle reads fine, so I dont worry about it too much. It cruises at 14.7 in closed loop so it looks to be accurate enough.
And unless he set your ecu up for WB closed loop control, the WB will have no affect on the tune. Its just a gauge. But if you had a leak before the oem o2, that would explain it, but you said o2 feedback is good...
Old Jul 30, 2012 | 05:15 AM
Capone24's Avatar
Ok ill have to check really good for exhaust leaks then. I dont think he set up WB to control closed loop but ill dbl check. I just thought how it was strange that whatever is making my WB read lean is also causing it to idle rough, like you said i thought it was just a guage. Ill dbl check those things today tho and let you know, thanks
EvO_essence
22
Jun 2, 2016 03:54 PM
Soda
Sep 8, 2015 08:23 AM
mrm95
Nov 1, 2014 09:30 AM
sound77
May 13, 2012 06:53 AM
