evo8 260 - changed maps - pls. check
Old Sep 2, 2012 | 09:10 AM
t2000cz's Avatar
Hello. I've had my evo8 260 for 2 years already and for some reason I decided to make the car faster.
After 2 months of reading posts on this site and some other ones I started to tweak the maps.
I decided to use the Ralliart map 99270000 and modified both fuel and ignition maps.
Now the virtual dyno says something like +50hp from the standard (I made the logs before I started the modification).
I have an ideas how to continue, but I would like to ask someone to check the maps and log for me, and tell me if I am in the right direction or I do something stupid.
The car is standard evo 8 260 with Japspeed downpipe, k&n panel filter, and it still has the second cat and original exhaust, standard fuel pump.
The boost is 1.5 bar.
I use the Innovate LC-1 wideband sensor for logging the AFR, which is mounted before the cat.
Thanks in advance..
Cheers.
Vit
