need some help please
Old Sep 29, 2012 | 04:43 PM
W2J's Avatar
W2J
will pay someone to tell me what is wrong and how to correct it. rename the ext to csv, and the rom is 90550701
Rom and log attached.
File Type: hex
Old Sep 29, 2012 | 05:07 PM
timv's Avatar
I think you need to be a bit more descriptive in what you need help with?
What problems are you seeing? WOT pull not smooth?
From the log, looks like your AFR is OK and your knock is in check but your timing jumps around quite a bit not smoothly and your logged load seems incorrect.Goes from almost 300 down to 4???
I'm not to familiar with your ROM but if you give more information, others may be able to help you more.
What year and model is your car?
What mods are done to it?
What fuel?
Good luck...
Old Sep 29, 2012 | 05:14 PM
W2J's Avatar
W2J
look at the TPS value in green the load drops to 70 and all over the place after 4k which makes no sense.
Old Oct 1, 2012 | 06:57 AM
W2J's Avatar
W2J
got through thanks.
Old Oct 1, 2012 | 08:16 PM
ecktt's Avatar
What was the issue?
ReaperX
Oct 12, 2016 01:00 PM
Tomvas1992
Jun 22, 2016 09:44 AM
Smolik1010
Jun 7, 2016 08:54 AM
BhpTuner
May 1, 2010 01:01 PM
evo L
Dec 28, 2007 05:34 PM
