Help Opening Map
Old Oct 31, 2012 | 04:07 AM
glitch_tt's Avatar
Help Opening Map
Hey Guys,
I am having problems opening my friend's evo VII map. It has the Tephra mod on there but I dont know what version.
The car was tuned by him and myself and is working perfectly. His computer crashed and he lost everything.
Can you guys please assist
Thanks in advance
File Type: hex
Old Oct 31, 2012 | 04:08 AM
glitch_tt's Avatar
we just need the *.xml file for that map
Old Oct 31, 2012 | 06:27 AM
glitch_tt's Avatar
anyone able to open this map??????
Old Oct 31, 2012 | 06:32 AM
todd6027's Avatar
its 90550001 v 5.10 , it needs a bit more work
should be in here
https://www.evolutionm.net/forums/ec...d-v5-10-a.html
Old Nov 2, 2012 | 06:13 PM
glitch_tt's Avatar
Thanks alot for the link but I cant seem to open it. I keep getting page cannot be found. Is it possible at all to upload the xml file?
Thanks in advance
Old Nov 3, 2012 | 11:46 AM
todd6027's Avatar
il have a look see if i can find it
Old Nov 3, 2012 | 11:58 AM
todd6027's Avatar
try these you need both xml
File Type: zip
File Type: zip
Old Nov 5, 2012 | 02:42 AM
glitch_tt's Avatar
Thanks a million...Quick question
Although i am not seeing the entire map...can I edit the fuel map and timing map and upload to the car and everything will work fine?
Thanks again
Old Nov 5, 2012 | 03:09 AM
todd6027's Avatar
whats missing ??
Old Nov 5, 2012 | 05:52 AM
glitch_tt's Avatar
this is what i see.
Is this everything that I am suppose to see with this map?
Old Nov 5, 2012 | 11:43 AM
todd6027's Avatar
when you click on the + does it open drop down
Old Nov 7, 2012 | 03:12 AM
glitch_tt's Avatar
yes it does and I can edit...I just want to make sure if I do edit the car will work normally.
Old Nov 7, 2012 | 07:07 AM
todd6027's Avatar
yep
Old Nov 7, 2012 | 03:20 PM
burgers22's Avatar
What are you using for boost control on that car?
Old Nov 9, 2012 | 11:45 AM
glitch_tt's Avatar
Manual boost controller at 22psi
thanks again guys...I just wanted to make sure
