weird problems with rescaling the Big Map
Old Nov 24, 2012 | 08:23 AM
Lancer_Evo_8's Avatar
I work with tephraV7 and now i have a weird problem with rescaling the tables.
If i try to rescaling the Load tables (1) (under 70 load) it changes automaticly the RPM table (2) (over 6500 rpm), and if i try to rescaling the RPM table (2) (over 6500 rpm), it changes automaticly the Load table (1) (under 70 load).
But the problem i have only in the Main Map Fuel Settings with the two tables of High octane fuel map & Low octane fuel map. The Alternate Fuel Map work perfect. Hope somebody know this problem. Here a two picts of my problem:
Old Nov 25, 2012 | 07:55 PM
Vigman's Avatar
It looks like a bad XML def.
Hope it helps.
Cheers.
Old Nov 25, 2012 | 09:51 PM
3K's Avatar
3K
Agree with vigman. Looks like you'll have to start with a fresh rom. Or you might get lucky if you pull the rom in your ecu, save and rename it. open it and see if the issue still exists.
Old Nov 26, 2012 | 12:12 AM
@ 3K
Its not dangerous to load the Rom with the def XML in the EVO ecu? I want load my file in the ecu when the file is completly finish and ready to drive.
Old Nov 26, 2012 | 02:14 AM
3K's Avatar
3K
No, you don't up load anything to your ecu, you're retrieving the rom from you're ecu. I'm assuming your ecu already has all your map settings minus the weird load scaling. So don't write to ecu, but read from ecu and save. Unless you don't have any written rom in there now, (Which it kinda seems like after re-reading your post.) I would suggest starting with a fresh stock rom xml and transfer your maps and settings.
razorlab
Sep 14, 2019 07:23 AM
richardjh
Jul 28, 2017 03:49 PM
EFIxMR
Jan 1, 2015 05:27 AM
mrfred
Jul 29, 2014 09:41 AM
