ECUFLASH will read but not write
Old Jan 17, 2013 | 08:17 PM
NigHtcRawl3R's Avatar
Hey guys
Tried reflashing a friends car. Strange issue that I'm having, I havent had an issue like this before. I can read the rom from the ecu but when I make changes and want to write it back onto the ecu, it wont let me
The battery voltage is about 12.7v which I think is sufficient, below 12v is when ecuflash wont read/write. I've also tested the equipment on another friends car and it works ok so that eliminates the cable/laptop/software. Also used ecu unlocker and that didnt work.
If the ecu was blocked/locked, I wont be able to read it either I think
Using ECUFLASH 1.44 and 2.0 openport tactrix cable.
JDM evo 8 with rom id 93660005
This is what I get from ecuflash log:
[20:35:08.429] J2534 API Version: 04.04
[20:35:08.429] J2534 DLL Version: 1.00.3210 Nov 22 2010 23:18:50
[20:35:08.429] Device Firmware Version: 1.11.3209
[20:35:08.429] Device Serial Number: TA5QDZH9
[20:35:11.043] sending init sequence 1 (0001)
[20:35:12.051] got 0x05 response
[20:35:12.051] sending init sequence 2
[20:35:12.058] got 0x1B response
[20:35:12.058] sending init sequence 3
[20:35:12.392] entering bootloader
[20:35:12.394] sending kernel size (0)
[20:35:12.398] sending kernel load address (0xFFFF6000)
[20:35:12.402] uploading kernel
[20:35:12.402] verifying kernel checksum response
[20:35:12.402] kernel valid
[20:35:12.405] sending init sequence 2
[20:35:14.407] interface close
Any ideas?
*SOLVED*
Old Jan 18, 2013 | 02:14 AM
awadkhan's Avatar
that usually happens when the battery is low try it with a fresh charged battery from some other car....
Old Jan 18, 2013 | 08:15 PM
Thanks man. Problem solved.
Old Jan 19, 2013 | 08:46 AM
stunt2's Avatar
was it low voltage fault ?
Old Jan 20, 2013 | 11:14 AM
Yea. For some reason it wouldn't work with 12.7 volts. Bought a new battery and she was all good to go.
NightHawk
Jun 8, 2015 06:28 PM
DarkerStars
Mar 4, 2015 11:52 PM
wreckleford
Lancer Engine Management / Tuning Forums
May 20, 2012 11:35 AM
