evo rom
Old Jan 17, 2013 | 11:24 PM
sound77's Avatar
evo rom
solved !
Old Jan 18, 2013 | 01:21 AM
german_evoVII's Avatar
I dont believe that they messed also the second description of the rom.
so:
Its an JM8859 type, so it can be 88590013 88590014 88590015 or some tephra derivat.
take it at your own risk, you have to try the right definitions.
Edit.
So an 88590013 looks right, immobilizer is visible.
you have to edit f52-f55 fields in the rom with an Hex editor to "1234" instead the "*¼Ïï".
Then make the xml ( make a copy of an 88950013.xml, rename the part <internalidhex> from 88950013 to 1234, and save it )
then use Ecuflash as normal
cheers
steffen
Old Jan 18, 2013 | 05:24 AM
sound77's Avatar
solved
Old Jan 18, 2013 | 07:50 AM
todd6027's Avatar
rom id has been changed to ADBCCFEF
try attached it opens it but you may check to see if all the tables are right
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
