Need some help tuning my car, just got her back from being built
Since I don't want to eliminate the knock control below 100 load I need to raise my knock base correct? This is due to the increase in engine noise in having a built motor/balance shaft delete that is increasing the noise or knock adc.
Since the knock adc is raising over the knock base this is generating a knock sum. However since my car is no longer stock this knock sum is not actually knock just noise. I just want to make sure i'm thinking about this in the right way.
Also, the only det cans I could fine online were by Phormula and I won't have those until the middle of next month because they're based in the UK. I found a review of them on this forum and think electronic det cans would be the way to go since this isn't idle knock. Also no one I know that's close to me tunes their own cars or owns det cans.
Should I update my knock threshold table or knock multiplier? I'm leaning towards the multiplier since there will be an increased resonance with my built motor. Is raising it 10% a good way to start? I'm sure others have had this issue. Just want to get to tuning my motor and enjoying my evo again. I really appreciate the help.
You can make your own det cans. I think I even saw something at harbor freight that may work.
Also, try putting 100 octane and see if it reduces knock.
I'm still leaning towards phantom knock.
Use a set of ear protectors and a piece copper pipe flattened with a hole in it to bolt on centre inlet manifold stud run some tube from the copper . drill a hole in the ear protector cover use a plastic pipe bulkhead fitting
to fasten it to the cover, put the pipe on the fitting, job done
I changed that and it fixed my issue. however my octane number is still on the decline. It's around 67%. My car isn't showing any knock when I log however it won't raise the octane number. Is this normal?
So since i'm staying out of the boost since I only have 300 miles on the build it won't raise the octane number? That does make sense that it keeps going down and won't raise because I haven't seen over 4 psi since i've had the car running.
I was under the impression that when you re flashed a 9 ecu as he did when he changed th eknock load settings that everything resets
Possible. Would have to see the map to tell if that's a possibility.
