8858 XML improvement. 88580714 88582714 88586714
Old Jun 19, 2013 | 07:42 AM
211Ratsbud's Avatar
Thing is the roms are not always disassembled by the same person, and the XML could be listed slightly different. I only combined various XML data to make one semi complete XML listing from what was available and recently found.
I had hang on 8859 but not on my 8858.
Old Jun 20, 2013 | 12:33 AM
el.guerrero's Avatar
Mm waiting boosting perf answer.
Thanks
Old Jun 24, 2013 | 01:24 AM
XR6T's Avatar
I found that I could get rid of rev hang by just adjusting this table. It took me a while to find it and in our ROMs it starts to pump the ISCV demand from only 3000RPM. With everything else put back to stock adjusting this one solved it for me.
Give it a go, hope it helps.
<table name="ISCV Demand RPM Adder [rpm > 4500, load > 170, speed > 12 mph]" category="ISCV Control" address="6468" type="2D" level="2" scaling="ISCV_AX2_8">
<table name="RPM" address="7ffc" type="Y Axis" elements="10" scaling="RPM"/>
</table>
Attached Thumbnails 8858 XML improvement.  88580714 88582714 88586714-revhang.jpg
Old Jun 24, 2013 | 04:28 PM
211Ratsbud's Avatar
I did include that in the op for those who are gettin this stuff.
Old Jun 30, 2013 | 10:15 PM
wrx2evoIX's Avatar
I made sdome MIVEC changes only and noticed the values in ISCV Demand Baro Adder**** (FFFF7C0E) (sub_1F6E6) [sub_1EFC0] were affected.
Further experimentation isolated it to the values in the the MIVEC table at Engine Load 280 and RPM 750, 1000, 1250 and 1500.
Is the address for ISCV Demand Baro Adder**** (FFFF7C0E) (sub_1F6E6) [sub_1EFC0] incorrect at 6b00?
Old Jul 4, 2013 | 03:43 PM
211Ratsbud's Avatar
I'm going with yes it is incorrect
Ill do a little digging in my pms later to see if I have more than one source there
Old Jul 4, 2013 | 03:52 PM
211Ratsbud's Avatar
Looks like that was carried over from the original set of xmls and not from newer stuff by donner and xr6
Old Jul 10, 2013 | 12:46 AM
XR6T's Avatar
Mmm, good pick up, it seems to be an incorrect address from way back. I have had a look at the code and it looks like the table address should be 3dfe. The axis address looks right.
Old Jul 11, 2013 | 08:59 AM
211Ratsbud's Avatar
I will make that change to the zip here soon. I'm on sd so baro doeth not worketh
Old Jul 19, 2013 | 05:46 PM
wrx2evoIX's Avatar
There's two ISCV Demand Baro adder elements in the XML. If we change the address in the second one to 3dfe they'll both be the same? It's the one with the 6b00 address that's linked to Mivec intake advance. Maybe we ditch the second one unless the address can be verified?
<table name="ISCV Demand Baro Adder (FFFF6E98) (sub_1E1EE)" category="ISCV Control" type="2D" address="3dfe" level="2" scaling="ISCV_AX2_8">
<table name="Baro" type="Y Axis" address="6f30" elements="5" scaling="Baro16"/>
</table>
<table name="ISCV Demand Baro Adder**** (FFFF7C0E) (sub_1F6E6) [sub_1EFC0]" category="ISCV Control" type="2D" address="6b00" level="2" scaling="ISCV_AX2_8">
</table>
Old Jul 19, 2013 | 06:01 PM
211Ratsbud's Avatar
Damn you're clever, my sd rom doesn't have baro so ill never use that. But I can just retag that 6b00 one as (incomplete) for now baro is rarely necessary anyways. ( but obviously nice to have correct )
Good call!
Old Aug 5, 2013 | 06:44 AM
211Ratsbud's Avatar
Update I still haven't corrected the issue above .. Been too lazy! Just be aware lol appearantly it's redundant anyways
Old Mar 22, 2014 | 09:21 AM
khara's Avatar
good work guys
so is there a final xml after all this add and modified tables?
what is better 8858 or 8859 ?
Thanks for all
Old Mar 22, 2014 | 09:53 AM
211Ratsbud's Avatar
Should be in the first post. 59 has more support and more attention . This was my idea to draw some here. I've attained smoother running with 8858 with less tuning. Specifically idle.
Old Mar 22, 2014 | 01:05 PM
khara's Avatar
Thanks for everything
So after I replace the new improved .xml file in the (EcuFlash directory),
what do I have to do ?
reflash with what .bin or .hex file ??
Thanks again
