CEL after ecu swap
Old Jul 12, 2013 | 05:52 AM
todd6027's Avatar
Originally Posted by MadMitsi
Hey i tried to get fault codes to come up for CEL but none come up? Although abs light constant flash when 1-4 are bridged. Confused now lol
can you post up the rom , what does the eng light do when the 1 and 4 pins are bridged
Old Jul 12, 2013 | 09:00 PM
philr8's Avatar
Save your self the head aches and put an Evo 5,6 ecu in it. The Ceddy mods rom is awesome! I've got 3 ecus in stock if you want to purchase 1. Phil
Old Jul 12, 2013 | 11:07 PM
MadMitsi's Avatar
CEL does nothing when 1-4 are bridged... Just the ABS light flashes constant fast that's all that happens.. I have an Evo 5 Ecu that I'm thinking of running that instead. Can't post up rom as i dont have access to the cable but I think the tuner has it saved on PC. (ill try get)
I've reset the ecu a few times by disconnecting battery for a minute or so, CEL goes away then about a minute later it comes back. and still not able to get a fault code to come up as said above :/ Just with Key on not car running
I seen somewhere that someone said evo 4 have 2 wire for o2 and evo 5+ have 4 wire? could this be apart of issue?
also... if i decide to use Evo 5 ecu instead, which air flow meter do I need to use? Evo 4 or Evo 7? Or do I need a evo5/6 one?
Old Jul 13, 2013 | 11:31 AM
todd6027's Avatar
could be a dodgy o2 but as the heater circuit is turned off (56d0 to 16d0) it would be unusual , mafs are all the same
Old Jul 15, 2013 | 08:26 PM
MadMitsi's Avatar
PLugged the Evo 5 ecu in and got no check engine light to come on but as far as i know that one isnt running any ecu-mod( also with it running the rewire for evo 7 you'd think CEL would be on??) If I can attach my rom to a file on here could someone have a quick look and see what's missing as to why I get CEL?
Old Jul 16, 2013 | 12:12 PM
todd6027's Avatar
yhpm
Alchem1st
Mar 15, 2022 08:47 AM
evolution4.7
May 27, 2017 03:16 PM
EVOXTACY
May 25, 2017 12:11 AM
onefast2gdsm
Dec 14, 2016 11:42 AM
Evo_AK
16
Sep 28, 2015 12:26 PM
