Logging 2byte Load with EvoScan & 96530706 Question
Old Jun 21, 2013 | 05:15 AM
Anubis18's Avatar
I'm hitting Load over 260, so I figured it was time to use 2byte. Well my 2byte load numbers are wayy different numbers. Almost like +100. I am using Tephra v7 96530706 and my 2byte to 1 byte load factor is set at the regular setting of 1.2.
Here is a screen of my Load on a map, 2byte to 1 byte load factor and my MUT Table. I'm not sure if my MUT table is correct but I thought it should be..
Old Jun 21, 2013 | 12:23 PM
Kakihara's Avatar
all I can tell you is that I recently switch to everything-2byte on my tephra v7 and really there's no reason to use load2byte and rpm2byte unless you hit crazy figures
numbers are nearly the same than load1byte (at least up to the 288 I saw) and the regular rpms really (up to 8100rpm)
the only useful one for me is 2byte airflow...BUT and that's a big one...as soon as I enable 2byte my power goes down by 10-20hp dynojet...don't ask me why or how, afrs are the same, boost and load too, the end result just isn't I've switched back and forth maybe 15 times...always the same results (and I've tried lots of maf scaling curves)..sometimes changing things too much doesn't work that well at leats on my car
evo9 fpgreen
Old Jun 23, 2013 | 07:20 AM
Anubis18's Avatar
Yeah I think I'm maxing it out
Old Jun 23, 2013 | 11:43 AM
Boosted Tuning's Avatar
You should be using 9417 V7 ROM on your car.
You should also be using just 1byte Load.
And theres no way your maxing out 1byte or 2byet load with a FP white.
Jack_of_Trades
May 29, 2018 07:05 AM
neuralcj
Jan 7, 2018 02:50 PM
Evo_Goodness
Sep 2, 2016 05:05 PM
Kaveeth
Jan 26, 2015 05:35 PM
