Fuel Trims not budging
Old Jul 7, 2013 | 07:06 PM
Big Bald's Avatar
Exclamation Fuel Trims not budging
I have tried every fix I found from searching this site. no matter what I do I can't get my LTFT mid and Lo to cycle. I made sure that the rear o2 is not disabled. I killed the battery and was able to get Lo to move once but not so much anymore. I am using ROM 96530706. My guess is there is some small setting i am missing or not set all together. I have FIC 950 injectors if that matters at all. They are scaled at 812. I tried scaling up but no luck. Any suggestions?
Thanks.
Old Jul 7, 2013 | 07:37 PM
07EvoIX's Avatar
I have to disconnect the battery every time I check my LTFTs. Works once and when I disconnect from the ECU I have to disconnect the battery again to check them again.
cheers
Old Jul 7, 2013 | 08:48 PM
Big Bald's Avatar
So after every change I need to disconnect the battery? Did not realize that. I was under the impression that the flash reset the trims.
Old Jul 7, 2013 | 09:22 PM
Raptord's Avatar
On the IX reflashing resets the trims, but not on VIII's.
Old Jul 7, 2013 | 09:43 PM
Big Bald's Avatar
Awesome......thanks for the replies.
william2565333
Jul 11, 2014 07:35 PM
Big Bald
Oct 11, 2013 08:13 PM
Jorge T
Feb 7, 2008 06:43 PM
joedr
Mar 18, 2007 01:04 AM
