Issues connecting EcuFlash to Evo 9
This is the message I am now receiving;
[19:36:26.467] Using interface OpenPort 1.3 Universal TX2I2IXh0caea4c535d9b68f63ab24f3df87b15a869a1df6
[19:36:33.264] sending init sequence 1 (0001)
[19:36:36.535] sending init sequence 1 (0003)
[19:36:39.801] sending init sequence 1 (FFFF)
[19:36:42.551] no response to any known code
[19:36:42.551] interface close
I am not able to connect to my ECU because my vehicle would have to be running first. When I attempt to read my ECU I follow the instructions and turn the key to the "on" location without starting it that I get the above message. I can't start my vehicle in order to get EcuFlash to read my ECU properly because I flashed it with a completely different ROM without taking into effect my immobilizer code to my key.
Is there any way I can read my ECU and reflash it correctly without starting my car? I have a Windows 8 laptop would this be a possible issue?
Thanks in advance
Thanks in advance
So you've flashed before and it works? Might wanna try and hook up a battery charger to it because the IX's are funny about battery voltage. Sometimes mine won't flash unless I let it run for a minute and charge the battery a bit.
EcuFlash just wont read it unless the car is running.
I was able to do it prior, this is the thing. The only way I was able to read/flash the ECU was when the vehicle was turned on and running. After I reflashed it I did it with a factory ROM which I did not edit to take the immobilizer into effect. Now the engine will not start because of this. So I need to access my ECU without starting my vehicle, but I cant because that is the error I get.
Is anyone out there able to read/write their ECU without turning the engine one?
This will solve my issues if I could get to do that.
You probably have a dying battery and need just a little more voltage, try a battery charger or a jump from a running vehicle.
Low battery voltage will do strange ****. It may not be low enough to do anything else tell tale but it will be low enough to screw with ECU Flash. Hook a battery tender to it and try again.
I don't think you should have to have the engine running to flash the car, I never do. If it won't flash I just start the car and let it run for a minute or two and then shut the engine off and flash with key on.
This happens a lot with evo 9's. specifically with the mini batteries. In this case Raziel you need to hook a battery charger up to the battery and let it charge, and if that doesn't allow you to flash it, then you need to replace the battery itself.
I basically just repeated what 90zcrex suggested.
The reason it flashes with the car running is because the alternator is assisting the battery with a charge.
Bench Flash
I have tried a jump and I was not getting anything past 12v. The thing is I will not be able to turn the engine on because of the fact that my engine is immobilized due to the ROM I flashed my ECU with.
Try bench flash , take your ECU out from the car and flash back to ori Rom
For everyone else, my battery is new and is reading 12.42 volts. I also had another car hooked to my battery as if I was jumping it in order to feed extra voltage to it. Still nothing is happening.
For the rest who don't get it, I cant start my car because I flashed my ECU with a different ROM which has a different immobilizer code than my original. I goofed and didn't realize that I should have taken this into affect when flashing. My car wont start until I reflash it with the correct codes.
Yes the other vehicle was running and I was getting a constant voltage of 12.35-12.42 Would this be sufficient in order to have EcuFlash read my ECU while my car is off and ignition key put into the 'on' position?
