Intermittent AFR's wildly swinging
Old Oct 18, 2013 | 04:24 PM
catman78's Avatar
Hi all,
Trying to determine what's going on.
Setup
FIC2150
E85
SD
Tial VTA Bov
EGR Delete
Seems more stable 1st thing in the AM.
Idles 14.5 - 15.3 or so
STFT close to +-2%
Cruise fine 2800-3k for 5 minutes or so
then AFR's start swinging, on Decel injectors stay Rich and don't shut.
after a bit it will recover eventually and be stable for a bit and Decel normally.
Any thoughts?
o2 sensor
MAP Sensor
thanks
Old Oct 18, 2013 | 08:29 PM
domyz's Avatar
Originally Posted by catman78
Hi all,
Setup
FIC2150
E85
SD
Tial VTA Bov
EGR Delete
STFT close to +-2%
Any thoughts?
o2 sensor
MAP Sensor
thanks
What are your LTFT ?
Is this happening as soon as the coolant reach normal temp?
Old Oct 19, 2013 | 06:17 AM
catman78's Avatar
domyz
I reset trims and LTFT Mid was heading towards -10% after a few cycles
so I'm guessing that's what the issue is.
Where should I remove fuel from RPM-VE or Map?
I don't want to screw up idle
I attached a log file for reference.
Thanks for your help. I appreciate your input
current settings
ReidFletcher
Apr 27, 2017 01:03 AM
teribble
Jan 31, 2017 08:22 AM
mt057
Feb 18, 2011 12:15 PM
dRifT iT
28
Jun 13, 2010 11:38 AM
johnnyr55
Apr 12, 2008 06:54 PM
