problems with tephra v7
Old Oct 28, 2013 | 08:02 AM
Rpf1evolution's Avatar
so i have an 05 evo with rom id 96940011 and i made the conversion to 94170715. ive done the big map conversion and switched over all my injector info and ecu info to get it started. first start it started and stayed running bout sounding like it was misfiring really badly. also after i cut it off and tried to restart it, it seems to just start and die now. what else do i need to be changing to make this work? i flashed my old map back on it and it runs just fine. im wondering if it has something to do with the MAF settings but i dont see anywhere to edit that. during the time being ill be double checking all the tables to see if i skipped over something. but from my understanding all you gotta do is fuel and timing big maps. injector info and immobilizer. anything else?
Old Oct 28, 2013 | 08:14 AM
Raptord's Avatar
MAP sensor settings maybe?
In EcuFLash 1.43+ you can use the "compare ROM" feature under the File menu. Obviously since many tables are different between a regular ROM and a tephra ROM there will be many differences, but it will also help you spot some tables that are the same in Tephra that you may have missed.
Old Oct 28, 2013 | 09:00 AM
thank you ill try that. im excited to have all the features, just hope i can make this work. i also do have the most current version of ecuflash and evoscan.
Old Oct 30, 2013 | 08:05 AM
also is there any way to convert tephra to read in celsius since the stock rom is?
Old Oct 30, 2013 | 11:22 AM
Raptord's Avatar
Just change the scalings, °C is probably already in there, but if not you can just add it.
domyz
Jul 27, 2022 11:54 AM
Spazm
May 24, 2016 09:15 PM
3bar_dc2
For Sale - Cars For Sale
35
Apr 4, 2015 07:22 AM
gotpsi?
Apr 18, 2013 07:19 AM
808boost
Jun 21, 2008 11:30 PM
