Tephra mod V7 IC Spray options
Old Jan 29, 2014 | 12:38 PM
evl gsr's Avatar
I have been trying to figure out a way to utilize the standard ECU to activate a shot of nitrous based on a set of conditions, i don't want to get an aftermarket ECU because i am huge believer in the standard ECU and i don't want to get a nitrous control box because i might as well buy an aftermarket ECU for the money.
i had a breakthrough yesterday when i found that there are already some conditions that apply to the IC Spray when on automatic which is almost perfect for me to use however the conditions just need some minor tweeks for example what i would like is the following options.
IC Relay control Min and Max RPM - instead of just Min
IC Relay control Min gear and Max gear - instead of Water Temp
IC Relay Control Min and Max Load or Boost - instead of just Min Load
TPS setting is currently perfect for what i need
I can work out all the wiring and relay work that's needed no problems the only thing i am no good at is re coding a bin file, was wondering how easy would this task be as its only changing the parameters, i have also figured out that if i can get this to work i can use altmaps to switch to the nitrous map while the conditions are met.
Any help would be greatly appreciated.
Old Feb 3, 2014 | 01:56 PM
evl gsr's Avatar
any one?
mrfred
383
Jul 16, 2024 09:29 PM
chetrickerman
Oct 20, 2015 07:10 AM
pitbulllove2003
Apr 2, 2015 09:37 AM
92LaserRs
Jul 17, 2013 08:26 PM
