XML for Subaru Impreza 2008_2.0l_M32r (Mitsubishi)
Hi need help creating XML for Subaru Impreza 2008_2.0l_M32r (Mitsubishi) who can help?
How much will it cost?
Especially need the map enrichment throttle
Since the pedal is pressed aksseliratora fuel air mixture reaches 15 A / F and detonation occurs. I sent this firmware different people, they could not do it. One hope for you
I have a little XML but not enough to properly configure the car. I can send rom and xml. I need to find a map on the throttle enrichment.
The problem is that the set speed of the fuel air mixture rises to values A/f15
at this point there is a detonation and ignition angle goes to -10 degrees
Correction Primary Open Loop Fueling not help
Start here:http://www.romraider.com/ I think you will find that most of the work has already been done for youl
Moore Auto
Evo X Dyno Results
Sep 11, 2020 09:00 PM
