Problem connecting Ecuflash to Subaru Impreza STI 2008
Old May 15, 2014 | 06:11 AM
franmf's Avatar
Hi, First of all I gotta say I've already tried the solutions given in the sticky posts.
I'm trying to connect Ecuflash to a Subaru Impreza STI 2008 and I'm getting always the same error.
This error:
[19:53:43.177] using metadata XML ID read_subarush7058can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush7058can.xml
[19:53:43.177] interface open
[19:53:43.192] J2534 API Version: 04.04
[19:53:43.192] J2534 DLL Version: 1.01.4247 Apr 18 2014 16:14:37
[19:53:43.192] Device Firmware Version: 1.15.4126
[19:53:43.192] Device Serial Number: TAYw8esE
[19:53:43.193] characteristics set to 0,8,1
[19:53:43.194] flush
[19:53:43.195] set pin 3 voltage GND
[19:53:43.916] kernel get version
[19:53:43.916] [W] 00 00 07 e0 01
[19:53:44.120] kwp2000 request requestCurrentPowertrainDiagnosticData - 1 bytes
[19:53:44.120] [01] 00
[19:53:44.120] [W] 00 00 07 e0 01 00
[19:53:44.123] [R] 00 00 07 e8 41 00 be 3f e8 13
[19:53:44.123] kwp2000 response to requestCurrentPowertrainDiagnosticData - 5 bytes
[19:53:44.124] [41] 00 BE 3F E8 13
[19:53:44.124] kwp2000 request requestVehicleInformation - 1 bytes
[19:53:44.124] [09] 02
[19:53:44.124] [W] 00 00 07 e0 09 02
[19:53:44.130] [R] 00 00 07 e8 49 02 01 4a 46 31 47 52 46 4c 48 33 38 47 30 33 39 38 31 37
[19:53:44.131] kwp2000 response to requestVehicleInformation - 19 bytes
[19:53:44.131] [49] 02 01 4A 46 31 47 52 46 4C 48 33 38 47 30 33 39
38 31 37
[19:53:44.131] VIN : JF1GRFLH38G039817
[19:53:44.131] kwp2000 request requestVehicleInformation - 1 bytes
[19:53:44.131] [09] 06
[19:53:44.131] [W] 00 00 07 e0 09 06
[19:53:44.136] [R] 00 00 07 e8 49 06 01 5c 97 99 ca
[19:53:44.136] kwp2000 response to requestVehicleInformation - 6 bytes
[19:53:44.136] [49] 06 01 5C 97 99 CA
[19:53:44.136] CVN : 5C9799CA
[19:53:44.136] kwp2000 request startDiagnosticSession - 1 bytes
[19:53:44.136] [10] 03
[19:53:44.137] [W] 00 00 07 e0 10 03
[19:53:44.141] [R] 00 00 07 e8 50 03
[19:53:44.141] kwp2000 response to startDiagnosticSession - 1 bytes
[19:53:44.141] [50] 03
[19:53:44.141] Requesting Seed...
[19:53:44.141] kwp2000 request securityAccess - 1 bytes
[19:53:44.141] [27] 01
[19:53:44.141] [W] 00 00 07 e0 27 01
[19:53:44.144] [R] 00 00 07 e8 7f 27 36
[19:53:44.144] kwp2000 error securityAccess -> exceedNumberOfAttempts
[19:53:44.145] set pin 3 voltage OFF
[19:53:44.146] interface close
[19:53:44.158] interface close
I've tried everything. With windows XP and Windows Vista. Installing drivers and so on.
Ecuflash detects the car because it auto enables "Read from flash memory" button. I select the right car type.
I don't know what's happening. The pins under the wheel are connected.
I'm pretty sure it is not a car problema cause I've already tried it with 3 different Subarus.
I'm using tactrix openport 2.0.
Thank you.
Old May 16, 2014 | 01:09 AM
IFuXwiTuZ's Avatar
this is EVOLIFE bro
Old May 16, 2014 | 02:29 AM
franmf's Avatar
I don't know where tu ask about my problem that's why I posted here
Old May 16, 2014 | 03:20 AM
rick1024's Avatar
nasoic is probably your best option dood.
CeliOnce
Sep 14, 2015 09:46 PM
Ross W
Nov 14, 2012 03:32 AM
waskarn
Lancer Engine Management / Tuning Forums
Jul 23, 2010 08:04 PM
andrew_7007
Northeast Region
10
Mar 29, 2009 06:57 AM
dsm25psi
Southeast Region
391
Mar 8, 2009 09:23 PM
