0015 boost limit/cut map issue
Old May 29, 2014 | 07:40 PM
10kLakesEvo's Avatar
I switching over from a 94170008 to a 0015 tephra 5.10. I was comparing tables in both maps to make sure there was no discrepancies. The boost cut or limit map in the 0015 tephra map is not the same as my 0008. I mean the numbers in the left hand column (rpm) don't even make sense i.e. 250, 281, 312, etc. In the 0008 map the correct rpms are there.
Do I just copy over the 0008 rpms to the 0015 map?
Old May 29, 2014 | 10:27 PM
jeffbeagley's Avatar
If the values in the left hand column are displaying incorrectly it generally means its scaling is missing or not defined correctly. Once you ensure that it is, you may scale it to your needs as you see fit.
Scaling for 9417 should be;
Code:
<scaling name="FuelCutLoadX2" units="%" toexpr="x*5/2" frexpr="x*2/5" format="%.0f" min="0" max="638" inc="2" storagetype="uint8" endian="big"/>
	<table name="Fuel Cut Load X2" category="Global Fuel Settings" address="3614" type="2D" level="2" scaling="FuelCutLoadX2">
		<table name="RPM" address="6dd2" type="Y Axis" elements="9" scaling="RPM"/>
	</table>
Old May 30, 2014 | 08:26 PM
Code:
    </table>
I checked the scaling for the 0015 5.10 modded rom and the address where it was pulling the rpm was incorrect. I have since changed it to the correct address you listed, and rpms are now there. Thanks man.
Tahoe55
Evo X Dyno Results
12
Aug 22, 2011 05:12 AM
EvoDan2004
Dec 5, 2009 10:46 AM
Broxma
Nov 15, 2008 04:05 PM
Nurburgring
Oct 13, 2008 08:12 AM
Slo_crx1
Nov 19, 2007 02:48 PM
