Strange idle problem with AC on
Old Jun 7, 2014 | 06:11 AM
TJung's Avatar
Hello guys. I have strange problem. Some time ago after engine built I had problem with idles - they were still at about 1500 rpm. I fix it with a ridiculous settings of my iscv tables (it was the only thing that worked). Now they are exactly as set in "Desired idle rpm" table. The problem is that when I turn on the AC my car stalls or even dies. I know that this is common issue in Evo's. I've increased values in "Desired ISCV initial step position with AC on-neutral" and it helped, but again without AC my car is having high idles (again about 1500 rpm). I don't know what to think about it.
My rom is 90550001 with tephra mods.
Here are my ISCV settings. Car idles great but without AC.
Old Jun 8, 2014 | 08:38 AM
TJung's Avatar
It's really hot now in Poland
Old Jun 8, 2014 | 03:38 PM
merlin.oz's Avatar
If you have hot cams, do the BISS setting thing in EvoScan to get the base idle speed under control. About 850 rpm for a cammy engine is ok. Then start messing with the ISCV stepper tables etc.
And do a through check for air leaks! I use a stethoscope, works a treat.
Boosted Tuning
Aug 26, 2023 10:14 PM
simple_lancer
Oct 14, 2020 02:18 AM
martinPL
Jun 10, 2016 01:20 AM
martinPL
Feb 4, 2015 07:55 AM
TouringBubble
Aug 1, 2008 07:33 AM
