Tephra strange problem
Old Sep 4, 2014 | 06:24 PM
GreeceS13's Avatar
I wrote Tephra 88580714 in my EVO9.
Everything was perfect.. stock map, stock boost 17psi spike.
I was started to increase the boost... I stoped to 27psi spike.
Perfect AFR low 11.. I was happy.
After some minutes without to change something I tried to run again.
Knock cels from 7psi boost and afr 13 and more.. and the car accelerate was crap.
I wrote again untouched 88580714 rom but still the same.
What the f@ck I did?
Old Sep 4, 2014 | 10:34 PM
jedibow's Avatar
Sounds mechanical to me, I would check to see if you blew off a intercooler hose, or one of your vacuum lines off the manifold...
Old Sep 5, 2014 | 12:25 AM
conroe's Avatar
tried to the OEM firmware?
Old Sep 5, 2014 | 12:39 AM
babu_rashu's Avatar
Check the vacuum line and intercooler hose.
Old Sep 5, 2014 | 01:29 AM
GreeceS13's Avatar
<p>Thanks for your replies!</p><p> </p><p>This was my first thought but when we have boost leak we have very rich afr right?</p><p>But it runs too lean.. </p>
I will check all hoses!!
Old Sep 5, 2014 | 08:37 AM
GreeceS13's Avatar
Old Sep 5, 2014 | 03:57 PM
GreeceS13's Avatar
Guys I check all intercooler hoses and vacuum pipes.
I cannot find any problem with them.
As I said boost leaks means rich afr!! And I have very lean afr at around 7psi..
The car spools ok until 7psi but after that it spools very difficult and like crap goes until 12psi.
I felt like intercooler hose but why the afr is lean?
Old Sep 5, 2014 | 04:49 PM
tsitalon1's Avatar
Sucking in air between MAF and turbo?
Old Sep 5, 2014 | 08:28 PM
GreeceS13's Avatar
I will check it too..
In partial throttle runs doesn't do it very much and I saw max boost 17psi..
So boost leak I don't think so.
I have stock untouched tephra map.
I try to write the previous map that I had but I cannot do it.
It gives an error
Old Sep 6, 2014 | 05:54 AM
todd6027's Avatar
lean spool on or off
Old Sep 6, 2014 | 09:23 AM
mcotton998's Avatar
Should lean spool be on?
Old Sep 6, 2014 | 09:29 AM
GreeceS13's Avatar
Untouched map so I don't know.
Finally I write in the ecu my old tuned map!
Still the same..
Lean mixture..
Maybe something with fuel system?
As I said with 70-80% throttle I haven't very easy lean condition..
With partial throttle I saw 17psi..
But again at partial throttle I had lean condition but not very easy.
Maybe because it doesn't need so much fuel like WOT runs..
What to do now? :/
Old Sep 6, 2014 | 09:33 AM
mcotton998's Avatar
Im pretty sure that lean spool is disabled in V7. When i was setting mine up i noticed start rpm and stop rpm for lean spool were the same which disables it.
I had the same problem you are having when one of the little hoses came off of one of the sensors on the intake manifold.
Old Sep 6, 2014 | 11:37 AM
GreeceS13's Avatar
Now I don't have Tephra... I wrote my previous rom so the problem isn't from ecu I think so.
I search all the hoses and I cannot find any came off
Also I tried to run WOT without to stop when I felt knocks..
I saw boost around 22psi so for sure isn't intercooler hose!
The afr at this try was around 14.... I felt many detonations.. Very crap running.. And ofcourse ready for destruction!!
I don't know what to check... MAF? Fuel pump? What the f@ck!!
Old Sep 7, 2014 | 09:51 AM
todd6027's Avatar
try the pump
