need help wih tuning evo8 ecu in 2g
Old Feb 4, 2015 | 11:17 PM
canclled's Avatar
current mods:
14b turbo
190 walbro fuel pump rewire
6an fuel lines from tank to rail
VRSF FMIC
1g BOV
4bar Map mitsu style with ait sensor SD set up
evo 9 pistons and rods
mtx-l wideband
autometer boost gauge
innovate oil temp/pressure gauge
stock injectors 450
stock exhaust
Saturn alternator swap
balance shaft delete
can somebody tell me if my ROM is right? I'm new to this and just want to know if everything in my ROM is good or if I need to change or fix something. thanks in advance
Old Feb 5, 2015 | 08:51 PM
canclled's Avatar
I'm getting this code also.
P0141 Heated Oxygen Sensor Heater Circuit Fault (Rear)
P0090 Fuel Pressure Solenoid Circuit
any help would be appreciated.
Old Feb 7, 2015 | 12:48 PM
Evilution226's Avatar
try this.....96533706-TephraMod-l2r99gst-dma-sd4bar.bin
Old Feb 7, 2015 | 06:51 PM
canclled's Avatar
thanks, ill try it tomorrow.
Old Feb 9, 2015 | 08:32 AM
canclled's Avatar
it worked but the P0090 Fuel Pressure Solenoid Circuit still on, I think my fuel pressure solenoid is going out because every time I turn on the actuator on evoscan while the car is running the check engine light comes out, also maybe the reason I'm running really rich. Also my Saturn alternator is connected to the fuel solenoid.
Old Feb 13, 2015 | 10:48 PM
MercenaryX2's Avatar
You need an AFPR since you rewired your pump. Use the regular SD rom, or even the 2.0 3D mapping.
silentsnipa
Aug 29, 2012 06:07 PM
longhornman
Nov 6, 2008 01:47 PM
han74j
Mar 17, 2004 05:42 AM
