54560003 2009 JDM Lancer Evolution X 5MT immobilizer issue
hi im trying to disable d immobilizer function for 54560003 2009 JDM Lancer Evolution X 5MT... im in malaysia...
ive followed as mentioned here but all tables greyed
https://www.evolutionm.net/forums/ec...0420-code.html
this is part of the log:
[20:10:43.749] -- reading ECU ID --
[20:10:43.874] ECU HW part number : 1860B221
[20:10:43.889] ECU SW part number : 1860B22101
[20:10:43.921] VIN : CZ4A-0101488
[20:10:43.921] interface close
[20:10:56.143] 54560003 (83 tables) inheriting evo10base (326 tables)
[20:10:56.159] mitsucan checksum module determined checksum area to be {{0x00000000-0x000fffff}}
[20:10:56.190] using metadata XML ID 54560003 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/54560003 2009 JDM Lancer Evolution X 5MT.xml
which inherits XML ID evo10base from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/evo10base.xml
[20:10:56.190] ---notes for evo10base---
2012/10/26 [Tactrix] Updating using multiple base file data sources including base file from Golden Evo repository.
2012/11/01 [Tactrix] Moved most non-address attributes from child files to base class. Standardized file naming. Change scalings on some code modifying tables (i.e. Mode 23 - IFMode 0x05 -> 0x23) to more strongly typed bloblist scalings.
2014/05/20 [Tactrix] Tactrix definition auto cleaned|merged w/ GoldenEvoMay2014.
---notes for 54560003---
2014/05/01 [Tactrix] Original file from Golden Evo repository. If this file is useful to you, please consider donating at http://goldenevo.com/
2014/05/01 [Tactrix] Moved most non-address attributes to evoxbase.xml base class. Standardized file naming.
2014/05/01 [Tactrix] Visually examined tables for obvious errors, but no in-car verification has been done.
appreciate for some lights how to disable it please
TQVM in advance
TQVM in advance
warning240
Lancer Engine Management / Tuning Forums
13
Nov 9, 2011 07:45 AM
Jblade
Mar 11, 2009 07:00 PM
