Help! Went to omni 4 bar now A/f very lean
Old Mar 19, 2016 | 11:15 PM
heliarcpro's Avatar
Originally Posted by Klaiceps
Those values are correct. Could you post up your ROM file here? I'll dive into it to see if I'm able to spot anything.
How do I post a file I see the insert image but can't do my rom file?
Old Mar 19, 2016 | 11:32 PM
kaj's Avatar
kaj
Click on "attachments" from the "reply" menu tool bar. It looks like a paper clip.
Old Mar 20, 2016 | 08:14 AM
heliarcpro's Avatar
My rom file.
File Type: bin
Old Mar 21, 2016 | 01:11 AM
heliarcpro's Avatar
Did you have a chance to look over my rom?
Old Mar 21, 2016 | 01:26 AM
Klaiceps's Avatar
Took a look and I can't spot anything out of the ordinary. I'm out of ideas on this one.
Old Mar 21, 2016 | 11:26 AM
heliarcpro's Avatar
Thanks for the help trying to figure It out.
Old Mar 21, 2016 | 08:42 PM
heliarcpro's Avatar
something else i have noticed im not pulling as much vacuum as i use to. i only have 8-10 inches at idle when i used to have 22. could this be the cause of the car not wanting to idle when cold? after it warms up it pulls 14-16 inches and tries to idle around 1050rpm but sounds like its missing and rpm will drop and almost stall. would my timing being out cause this. i put in a new set of plugs 100 miles ago. i was using one step colder but wanted to try the stock temp plugs to see if i got more life out of them. i have checked for vacuum leaks and found none. so what would cause my vacuum to drop off? timing issue?
Old Mar 21, 2016 | 08:47 PM
kaj's Avatar
kaj
A vacuum leak would explain sluggish acceleration.
Old Mar 22, 2016 | 12:04 AM
heliarcpro's Avatar
What about not ideling and lean af? If the timing needed to be adjusted what what cause this?
Old Mar 22, 2016 | 09:48 AM
kaj's Avatar
kaj
If you are drawing air at idle, that isn't metered by the MAF, then yeah..it would idle lean.
I once found a cracked vacuum line on the Evap or purge solenoid (i forget which). It took me a couple tries to find it.
Old Mar 22, 2016 | 10:57 AM
heliarcpro's Avatar
I'm running SD would a cracked vacuum line still make me run lean?
Old Mar 22, 2016 | 11:06 AM
kaj's Avatar
kaj
Oooh, SD. Hm....
It's been so long since I had a car without a MAF (especially with a vacuum leak), I honestly can't remember. I remember it hunting for idle, though.
I'll read back through your thread when I'm home. I'm distracted at work right now LOL
Old Mar 22, 2016 | 11:18 AM
heliarcpro's Avatar
Ok thank you.
Old Mar 22, 2016 | 11:47 AM
Klaiceps's Avatar
At this point, in addition to any possible vacuum/boost leaks, try checking your fuel system: injectors, fuel pressure regulator, lines, fuel pump, etc.
Old Mar 23, 2016 | 10:47 PM
heliarcpro's Avatar
so i did find a vacuum line off but after re attaching it the problems are still here. the car idles a little better but other then that nothing has changed. injectors all look good and are less then a year old. stock fuel rail but looks fine. the motor seems to be under load at idle because my turbo sounds like its spooling a little runing 1050 rpm at 8 inches of vacuum.
