AEM IAT , Omni 4bar MAP .. Testing
Old May 4, 2016 | 03:25 PM
EVO(boss)'s Avatar
Hi guys .
I have EDM evo8 MR 2005 its for Middle east spic . As it doesnt have MAP sensor from the factory . So i ordered Omin 4 bar and AEM IAT . I installed the IAT on in IC piping and wairing it to The MAF ( red/blue - Black) and got all pins from ECU (#73,81.92) and waiting it to the MAP sensor . Now how do i know if these are working or not ?
Got 2.0 cable , Evoscan ..
Old May 5, 2016 | 10:37 AM
Klaiceps's Avatar
Are you switching over to speed density? If so, have you checked out this thread: https://www.evolutionm.net/forums/ec...ched-roms.html?
If you have, then good. As for your question about the sensors, hook up your Tactrix cable, turn on Evoscan, and flip the key to the "ON" position. You don't have to turn the engine on. Look at the parameters on Evoscan to see if they are reading correctly. If your car is cold, the IAT should read ambient temperature and the MAP should read pressure at your present altitude.
sabrinaEvo
Dec 19, 2011 08:15 AM
mchuang
Aug 31, 2011 08:43 PM
Evoleader88
Dec 17, 2010 10:01 AM
Thugline
Mar 14, 2010 01:59 AM
2JZfan
10
Aug 20, 2009 11:38 AM
