EVO 8 2004 ECM/ECU Replacement Question
Old Aug 2, 2016 | 12:58 AM
Raceghost's Avatar
I could not find this on here, unless it is discussed hidden in a thread.
2004 EVO 8, possibly shot ECM/ECU. If I want a replacement that I do not have to disable the immobilizer, what can I do?
Will any of the 3 years work? Meaning I will be able to maintain the factory immobilizer circuit? Or must you disable it once you plug it in? Or utilizing the old periphery bits within ECUFlash, can I set the replacement to the proper settings and have the immobilizer circuit enabled?
Will another 2004 EVO8 Ecu work, since the immobilizer hex key is the same for all the 2004's?
Can someone square me away?
Goal is to repair/replace and maintain all features from factory in this respect.
Thank you.
Old Aug 2, 2016 | 02:49 PM
Raceghost's Avatar
Bump
Old Aug 2, 2016 | 05:02 PM
Raceghost's Avatar
Bump
Old Aug 2, 2016 | 05:18 PM
tephra's Avatar
should work, all you need to be aware is that there are a few different version of the evo8 ecu, some with 3 plugs some with 4..
or maybe that's evo7, either way, your best bet is to get one thats the same part number...
Old Aug 2, 2016 | 06:59 PM
Raceghost's Avatar
Ok. Check. Mine is 4 plugs.
Of course question then asks, what is the purpose of wanting to disable the immobilizer, if any 4 plug EVO 8 ECU works?
Old Aug 3, 2016 | 02:33 AM
tephra's Avatar
im not sure
Old Aug 3, 2016 | 09:01 AM
Raceghost's Avatar
Ok. Thank you again.
Dstorm7
Lancer Troubleshooting
Sep 25, 2016 04:43 PM
3011carlos
Aug 16, 2015 12:25 PM
06AznEvo
Oct 8, 2013 09:14 PM
