Help Please hybrid boost controller ECU settings
Old Aug 3, 2016 | 12:39 PM
ant_turbo's Avatar
Can someone please help me with the settings in ECUFLASH to run the hybrid boost controller setup,,, currently im set up for grimmspeed 3port and I want to run the
hybrid setup thanks......
Or no changes needed in ecuflash?? just simply install the boost controller to the desired boosting setting??
Old Aug 6, 2016 | 01:04 PM
ReaperX's Avatar
You tune the WGDC pretty much like you normally would with the exception of you increase the DC% later in the rpm to compensate for the fall off of the MBC.
Old Aug 10, 2016 | 06:46 PM
ant_turbo's Avatar
Where in what part of the map do I find that setting..
thanks,,
Old Aug 11, 2016 | 11:29 AM
ReaperX's Avatar
You'll find it under the Turbo heading if using a standard mitsu rom or Main Map Boost Control Settings if using a tephra rom.
Old Aug 11, 2016 | 12:15 PM
evo8426's Avatar
My advice would be to ditch the idea of doing hybrid boost, it doesn't do anything special and you are already tuned for the 3 port.
pensacola_evo
Apr 20, 2004 11:00 AM
sneaky8
Feb 9, 2004 03:03 PM
beast464
Sep 28, 2003 07:35 AM
