Tephra V3 alt maps switching - how ?!?
Old Jun 23, 2017 | 02:21 PM
YaroRS's Avatar
Guys, I can't figure out how to switch alt maps in V3 ? Can someone advise me how to do it ?
In old versions I could enable it to switch using throttle pedal, in V3 can't find such option.
Old Jun 25, 2017 | 12:15 AM
eTiLiKo's Avatar
Originally Posted by GP148
In the rom, you need to indicate how many alternate maps you want (1-9) then after you have flashed the car, either while the car is running or ignition on, hold the on/off Cruise control button on the wheel. You will see the intercooler spray light flash on and off. While it is flashing, press up or down on the raise decrease cruise control buttons, 1 for up 1 map from where you are at, twice for two maps up and so forth. When you are done, the intercooler spray light will flash the amount of times that signifies your map number, 1 flash for map 1, 2 flashes for map 2 and so forth. No flashes means you are on the base map
This is for SST cars. For normal cars the tacho needle indicates which map you are selecting
Old Jun 25, 2017 | 06:05 AM
richardjh's Avatar
I've got Tephra's XMod v3 on Ralliart. To switch maps, I do the following:
- Hold down Cruise Control button until the CEL starts flashing.
- Press the cruise UP (or DOWN) button to swich maps.
It will then flash the ICS (intercooler spray) indicator on the dash to indicate the map number (no flashes = main map, 1 flash - Alt Map #1, etc.)
And that's it.
Rich
mines5
Aug 10, 2017 05:32 AM
Raceghost
Nov 16, 2016 08:53 PM
hearnoevo
Mar 22, 2012 09:08 PM
Seijuro
Mar 18, 2010 03:09 PM
fostytou
Jun 6, 2009 01:43 PM
