Evo 8 Exhaust Pops + Bangs
Old Apr 5, 2018 | 09:57 AM
4G63_Crazy's Avatar
5 Year Member
Hey everyone *Im a noob so mind my stupidness of ECUflash*
So I was playing with ECUFlash, and looking on the forums and was wondering if it was possible to achieve nice sounding pops and bangs, but not to overly aggressive (something like a cooper S or focus RS pops) I've seen people run -10 to -15 degrees of timing in load columns 0-20. I decided to run -5 degrees in those columns, not sure if thats not enough or needs to be increased to actually have some nice pops. Also, has anyone had knock occur with a map like this? Heres my high octane ignition map, if anyone could help me, that would be great, thanks.
Old Apr 7, 2018 | 02:37 AM
Evo VI.'s Avatar
Every car is different!
What works for one won’t for another.
-5 is usually only enough to create a burble.
to get whip cracks or louder I would start at -10.
i run -20 btw 😎
Old Apr 7, 2018 | 07:41 AM
4G63_Crazy's Avatar
5 Year Member
i run -20 btw 😎
Yea I set mine to -10 and im getting some nice pops, but afterwhile gives me a little headache haha. Wow, have you had any problems with pulling so much timing?
Old Apr 7, 2018 | 03:25 PM
Evo VI.'s Avatar
none at all and been running it for over 4 years.
My cast manifold is ported and all the bangs happen in there so no exhaust gasket issues or any valve issues.
As long as fueling/map is good, should get no knock.
Old Apr 7, 2018 | 06:59 PM
2006EvoIXer's Avatar
I've heard lots of pops and bangs from evos using anti lag. Racers inject air (for oxygen) in exhaust manifold to burn the fuel after they exit the head. This causes an addition combustion in manifold to spin the turbo during launch control and in between shifts. Pops and bangs go out tail pipe if using test pipe.
Old Apr 7, 2018 | 07:46 PM
4G63_Crazy's Avatar
5 Year Member
Nice.. What's your starting rpm for the pops?
Old Apr 8, 2018 | 03:14 AM
Evo VI.'s Avatar
this is not anti lag we are discussing.
With fueling and mapping you can stop fuel gettting into your “test pipe”, and limit it to the manifold.
Old Apr 8, 2018 | 03:17 AM
Evo VI.'s Avatar
I have it set currently from 3500rpm to 6500rpm.
Again depends on map which load is best.
since I’ve run bigger cams and more HP, my load range on decel is from 30-100.
I’ve spent a lot of time fine tuning so it doesn’t affect part throttle driving, which the naysayers who know little about mapping will tell you your car will be horrible to drive when cruising.
Not always the case.
Old Aug 28, 2019 | 08:19 PM
robwvii's Avatar
Sorry for bringing up and old thread, but i'm in the middle of trying to achieve a few crackles and pops in my 7. I have changed the timing i have pulled timing to -20 between 2000 and 7500 rpm from 0-30% load as this is what i have seen others do but i have not been able to achieve anything, did you have to play around with your decel fuel cut at all in order to get the pops and crackle?
Old Aug 29, 2019 | 03:16 AM
jozy's Avatar
yes you either feather it or disable decel fuel cut
Old Sep 1, 2019 | 07:33 PM
jozy's Avatar
or if you have the SAS tables i think you can squirt fuel in too using that function although no air injection is possible
Old Mar 18, 2020 | 08:50 PM
PrinceMark2020's Avatar
How to do pop and crackle
Hi dude i was wondering how u guys do the pops and bangs with flame? To be honest i’m newbie here i have evo x gsr 2012 and i really want those! I don’t know what and how to start to do it i really need your help thank you in advance u can email here too markmeneses_28@yahoo.com
Old Mar 19, 2020 | 06:18 AM
bboypuertoroc's Avatar
Veteran: Army
Old Mar 19, 2020 | 07:52 AM
forc3 f3d's Avatar
cuz its kewl yo!
Old Mar 19, 2020 | 08:53 AM
Biggiesacks's Avatar
Every time i hear a car popping all crazy this is what I think of
Skip to 40 seconds for hilarity
"It's that WOOO WOOOOOO"
