sd 2.0
Old Apr 30, 2018 | 04:53 PM
butte's Avatar
Originally Posted by nor11384
Yeah I read it but I'm trying to understand a bit. So map volts vs kpa is not touched. Kpa to load I just copy the values over from my regular sd rom from map sensor ve calibration. Now what the hell is baro vs kpa? What I understand from all this is that the 3d map is both tables from the regular sd rom combined right? I get that everything is on the first page but I'm not fully understanding. I'm asking for a brief explanation so I can decide whether I want to switch or not. Maybe I'm not very smart and need it explained idk.
I'm going through the same process that you are right now, lol
Old Apr 30, 2018 | 05:41 PM
nor11384's Avatar
FCOTM Winner
If someone could just take 5 minutes and explain it then all would be good.
Old May 1, 2018 | 04:02 PM
nor11384's Avatar
FCOTM Winner
Any 2.0 users out there if you could please confirm that only the 3D table is used and all the others are left 1:1 or if you could please give a brief explanation. I read that you can bring your values over from regular and rom. Are they referring to map kpa vs load table? What does Baro va kpa do and should it be left alone? I’m waiting for this info to make a decision on whether to switch or not.
Old May 1, 2018 | 10:31 PM
nor11384's Avatar
FCOTM Winner
After reading I guess you leave everything 1:1 and just mess with 3d table.
Old May 2, 2018 | 07:53 AM
butte's Avatar
Any idea if you're supposed to touch the MAF scaling table? The SD 1.0 thread says these are a part of the equation but it's not clear to me when it's appropriate to change them, if ever
Old May 2, 2018 | 10:00 AM
nor11384's Avatar
FCOTM Winner
I had to messed with maf comp table on regular sd map to help with fueling down low.
