High knock on 4th gear.
Old Aug 16, 2018 | 02:12 AM
TariqEvo's Avatar
Exclamation High knock on 4th gear.
So, i just installed a 3-port gm ebcs, and I pretty much got 3rd gear nailed down, little work left.
but problem I am facing is that 4th gear pulls get me high knock even shifting 3rd to 4th.
i have checked afrs, load and timing and i dont see what is causing the knock.
I have attached a 3rd gear pull going into 4th gear. and also a 4th gear pull itself.
TariqEvo's Avatar
Update:
Forgot to mention, I am on speed density
Old Aug 16, 2018 | 02:31 AM
TariqEvo's Avatar
Update: Attached logs
have colored out where the knock is
File Type: csv
File Type: csv
Old Aug 16, 2018 | 09:00 AM
Abacus's Avatar
If its stock compression, your timing is a bit high across the board. Even if you have Ethanol/race fuel. Its better to prevent knock then it is to try and stop it once its happening. Look over the "timing" thread and others and gather some more information.
These engines don't need a lot of timing to run well.
Old Aug 16, 2018 | 09:23 AM
TariqEvo's Avatar
it's knocking at 5* of timing at peak boost. how low of timing should I go before the EGTs go high?
Old Aug 21, 2018 | 11:51 AM
TariqEvo's Avatar
Update:
I managed to fix this, apparently it was both rattles and real knock which contributed,
then also tuned out the afrs and smoothened both fuel and timing maps
