Base map
Base map
Hi, I had a 35r in my Evo 8. The car was tuned for speed density with Omni 4 bar and GM IAT. I have since then put back the stock turbo and changed to smaller injectors. I have set injector scaling and it fired up but runs a little rich. I also noticed that in evo scan the car idles with load @ 120. Shouldnt this be closer to 40s? Anyways, is there a base map I can put on so I can drive it to a tuner?
Thanks.
Thanks.
Your sd to ve value are most likely off
Pull fuel or add less VE under 1500 rpm
thing is just way off pay a professional tuner
I would just pull fuel on idle and drive it over to a tuner...you can do it with your ve settings
SD RPM VE pull fuel there I would start with idle
