can anyone identify what is wrong?
Old Jan 20, 2019 | 06:19 AM
matt1937's Avatar
car is a bone stock evolution 7 with tephra rom v7 94170715. no engine codes
but my load in logs goes down the 0 load% column when im logging. normally it should go across and down. i attached a log
thanks
Old Jan 20, 2019 | 11:17 AM
Biggiesacks's Avatar
are you logging tephra 1-byte load? In my evoscan its called "Load 1-byte". Then also make sure the evoscan function matches what you set in ecuflash.
Old Mar 14, 2019 | 09:17 PM
unkn0wn.'s Avatar
x2 My rom came with a load factor of 1.2 but the XML data for evoscan in the thread had an eval of 1.3*x
