Logging Boost with AEM X-Series 30-0306
Old Mar 1, 2019 | 05:30 PM
VEVO-8MR's Avatar
Hey all, looking for some help and options to log boost with evoscan using a AEM boost gauge.
I'm looking to log boost using the factory ecu / evoscan using the output from the AEM 30-0306 boost gauge which comes with a 3.5 bar sensor. I haven't found any threads specifically about the 30-0306 gauge but in general from the research I've done it looks like others have wired up the signal output from the boost gauges to pin #73 or #92 depending on if its a 3 or 4 plug ECU.
My evo is a 04 JDM VIII MR - no map sensor on these models (as far as I'm aware) so unfortunately I can't just buy a 3 bar map sensor and connect it up to the plug on the IM like with other models.
I wanted to double check with anyone else that has done this if this is correct and also which wire would I be connecting to the ecu? The gauge is currently wired up and working fine.
Cheers
Old Apr 13, 2019 | 08:15 PM
VEVO-8MR's Avatar
Just in case anyone is looking to do this, I ended up connecting the White 0-5V wire to pin 92 on the 8MR ECU and function (0.2488*x)-20.648 in EvoScan. If someone could explain why this function works and the one above in the mannual does not work that would be helpfull.
In EvoScan I used the below settings:
- Display: Boost GM-3Bar MAP
- Request: 38
- Function: (0.2488*x)-20.648
I am running ROM ID 96260709 Tephra V7 and did not make any adjustment to the MUT Table in EcuFlash. If you are new to this some things to note:
- the white 0-5v + wire cannot be connected to any free port on the ECU, it must be a ACD port (Analog to Digital), from what I have read on the 8MR ecu pin 92, 73,74 are all ACD.
- the brown 0-5v - wire must be connected to a ground point. If you notice in EvoScan the reading jumping around or innaccuarte it could be a bad ground connection.
- the function (0.2488*x)-20.648 worked for me and, you may need to tweak this.
- at idle the reading in EvoScan will not match the gauge - this is a known issue. The reading should match once under some load.
Cheers
Old Apr 14, 2019 | 09:39 AM
Biggiesacks's Avatar
i just finished rewiring my zeitronix into the ecu and it too had a similar discrepancy. The equation given by them was (volts)*2+9.6 but it ended up being (volts)*10+9.6 to line up. I'm not sure if that means the assumption 0 volts=0 and 5 volts=255 (0.0196*x) is wrong or what the deal is. It could just be analog signal error due to different ground potentials, but I wouldn't expect such a dramatic effect, and my zeitronix is grounded through the ECU grounds so it seems less likely.
Old Apr 14, 2019 | 11:13 AM
double post
Old Apr 19, 2019 | 05:20 PM
VEVO-8MR's Avatar
Tapping into the ECU ground sounds like the smarter and tidier way to do it, maybe that's why I had to a just my equation..?...I might do that when I get around to connecting the AFR gauge to the ecu.
Old Apr 19, 2019 | 06:58 PM
It helps eliminate the chance that they are at different ground potentials which would screw with the volts the ecu sees coming out of the wideband.
