Help can not connect to ECU
Old Mar 18, 2019 | 02:40 PM
unkn0wn.'s Avatar
Originally Posted by Pal215
I had the same issue you are describing and it ended up being my 1.3u cable. See if you can trade with a friend and verify that is not the case. It is rare for the ECU itself to fail.
I noticed ecuflash doesnt show the whole serial number for the cable so maybe youre onto something?
Old Mar 18, 2019 | 02:50 PM
Pal215's Avatar
It's definitely worth a try. When it happened to me, I checked every fuse in the car and traced every pin from both the OBDII port and the pin from the white connector to the ECU. All the connections were good and the car drove fine. I even hooked up my car to a running vehicle so I can get the 13+ volts while the evo engine was off .
Ended up finding out that it was my tactrix 1.3u cable all along. It turns out that if you keep them plugged in too long it ruins them. I found out the hard way.
Old Mar 18, 2019 | 02:55 PM
Biggiesacks's Avatar
He said even a code reader wouldn't connect to his ecu.
Old Mar 18, 2019 | 03:03 PM
Mmarlow123's Avatar
I don’t think it’s the 2.0 cord it worked fine when I pulled the map from the ecu and I can’t even get a obd reader to connect either.
Old Mar 18, 2019 | 03:28 PM
blackline's Avatar
5 Year Member
Going to unplug mine. lol
Old Mar 18, 2019 | 05:09 PM
unkn0wn.'s Avatar
x3 on that one, right after I run the cable super clean through my dash & out my glove box lol
Old Mar 19, 2019 | 06:39 AM
you can install a switch on the 12volt constant line going into the obd connector. So you can just turn the cable off. Its what i did with my openport 2.0 to keep it from draining the battery.
