need help with evo V logging/tuning/cable needed
Old May 11, 2019 | 05:21 AM
kobi411's Avatar
(hey guys is it appropriate here? mods pls move if necessary..)
i have read most forums re: the matter but wanted to confirm/ get updated im confused of what to do..
i have 2 friends that has evo v, and want to do an e-tune is it possible with ecu flash now? if it is..
cable: use tactrix 2.0 plus the reflash connector needed; correct?
do i need a different cable for logging as well? or just same?
i have an evo x and e-tuned as well so have bit of knowledge here, just helping my friends for now, and also wondering how to proceed..
pfa
Old May 12, 2019 | 08:44 AM
foxbat's Avatar
You'd need the Evoscan software for data logging and a wideband reader
Old May 12, 2019 | 09:00 AM
kobi411's Avatar
yes of course.. we have all except i dunno if the right cables i said were appropriate.. i have evoscan and ecu flash
so it will read the rom?
Old May 12, 2019 | 09:13 AM
foxbat's Avatar
Yes sure, with a Tactrix 2.0 you should be able to read & write to the ECU, you'd need the small white connector for flashing the ECU, if you don't have it then simply wire a cable, it's just one cable.
