N/A 2008 Lancer GTS ROM ID
Old May 29, 2020 | 07:46 PM
Rey D's Avatar
I need help with getting a ROM ID for my 2008 Lancer GTS CVT
Thanks.
Old May 30, 2020 | 04:11 AM
crimson red's Avatar
Thanks.
The address of the ECU ID starts from 0x5002a(to 0x5002d).
Open your ROM by a binary editor and look these addresses.
If the binary editor shows '51 51 00 23' from 0x5002a to 0x5002d, then your ROM ID is 51510023.
If you can't check your rom id following above way, just attach your rom to your next post.
#First you need to read and save your ROM from your ECU using the ecuflash and openport.
Old May 30, 2020 | 10:20 AM
Rey D's Avatar
Awsome! Do you have any xml files for my rom? it'll help a lot.
Thanks,
Rey.
Old May 30, 2020 | 10:23 AM
Rey D's Avatar
Here's my ROM,
How would I be able to make a xml file for this rom?
I've been searching around and I can't find one that works with this.
Thanks,
Rey.
File Type: bin
Old May 30, 2020 | 11:29 PM
1. Download 51510023.xml from danny1058's post at openecu.org.
2. Open the xml by a text editor.
3. Replace "DoMode 0x42 -> 0x52" to "DoMode 0x39 -> 0x49". (It seems wrong addresses.)
4. Place the xml into your 'ecuflash/metadata/mitsubishi/lancer/' folder.(If a xml for 51510023 is already exist, backup it and replace it.)
5. Place attached 51520026.xml into your 'ecuflash/metadata/mitsubishi/lancer/' folder.(It inherits 51510023.)
(Replace "XDM" to fit your car market. I don't know which is your car's market.)
6. You should be able to open your rom.
Warning: it is not proofed. Use it at your own risk. If you find a table with wrong address, please search correct address.
File Type: xml
Old Apr 21, 2021 | 10:40 AM
Israel Santoyo's Avatar
Hola amigo que tengo una versión estándar Lancer 2008 de lo que necesito archivo para abrirlo, lo marca me error ROM espero que me puedan ayudar amigo
File Type: bin
danny1058
Lancer Engine Management / Tuning Forums
Apr 21, 2025 01:05 PM
Abryant1985
May 29, 2020 09:21 PM
Bjorkovich
Dec 17, 2015 08:25 AM
Belgaram
Apr 12, 2011 03:51 PM
dadsgts
May 1, 2010 09:12 AM
