Which ROM for EVO9 with ALS but no SAS
Old Oct 15, 2021 | 06:09 AM
Pmart780's Avatar
5 Year Member
Hi,
I have in my workshop an EVO9 which has to be modified from road to Rally (I'm from France).
Up to now, it has a ROM (88840017), submodel of a EDM Base EVO9 (memory model SH7055).
The ALS is not shown in it.
Does somebody has or can provide a ROM which would have the following options:
- 2 maps (SP98 or E85), selectable by switch (to connect)
- 1 stage ALS selectable by switch (non existing now) with tables with 3D tables for ignition retard & fuel enrichment, piloting the Idle valve in order to have it full open in ALS mode and in parralel a magnetic Kicker, and with possibility to adjust the ignition cut % in order not to have an ALS pushing when engaged. The car does not have SAS, so airflow has to pass thru the Throtlle body...
- water spray output, selectable by switch (to implement)
- launch control
If somebody can help me, I would highly appreciate
Cheers
Pmart
Old Oct 18, 2021 | 06:48 PM
211Ratsbud's Avatar
Sincerely you should do some looking around. Read the Tephra Mod thread.
Go through my SAS/ALS thread.
8858 has a sd patched rom and also has functioning SAS. I've played with it quite a bit about a decade ago.
Clever individuals might be able to allocate the SAS solenoid output to activate the alt maps etc.
booster100
Jul 31, 2020 01:16 AM
besk
Aug 7, 2015 06:21 AM
SlowCar
Jun 18, 2006 05:31 PM
