Reflash to stock
Old Feb 2, 2022 | 11:33 PM
BrunoBoy650's Avatar
Reflash to stock
I am from CA and my 03 currently has a dual map setup. I have a tactrix cable and will purchase ecu flash/Evoscan to flash a stock rom back on. Other than copying my immobilizer, is there anything I need to do since it’s dual map? Or does reflashing the rom “reset” the entire tune to stock?
Old Feb 3, 2022 | 10:28 AM
black_out's Avatar
The calibration ID in the ecu is going to be different unless you have the original tune file for your ecu. Had a few people get flagged for ecu tampering with just a stock ROM reflash.
Old Feb 11, 2022 | 12:05 AM
I just did a stock reflash on my cousins 06 MR and just passed smog today. I bought my car tuned so no stock flash. Mitsubishi wants $350 for a stock reflash.
my ecu is part number:MN132874
I’ve looked on the ecu wiki and have seen a few different ROMs for 8’s. Which one is it?
Old Feb 15, 2022 | 01:54 AM
No one knows which is the exact Rom I need for smog?
Old Feb 15, 2022 | 04:09 PM
RazorLab's Avatar
This is flat-out incorrect information. Make sure you have the most current rom ID for your car/model and you will be good. It does NOT need to be the actual original ROM direct from your ECU.
Proven 50+ times.
Old Feb 15, 2022 | 04:22 PM
Pal215's Avatar
Proven 50+ times.
To be clear, you do NOT need the original flash that your car came with if you have kept your immobilizer code. The problem is many tuners don't keep your immobilizer code.
If you upload the most current rom ID and then edit the immobilizer code to your unique keys code, the CAL IDs/CVNs will match up, the engine will start, and you will pass. If you upload the most current rom ID and don't have your immobilizer code, then the engine will not start and you can't do anything. If you upload the most current rom ID and disable the immobilizer code in the tune by flipping the periphery bit, your engine will start but the car will not pass because that part of the tune changes the CAL ID or CVN. I forget which.
Old Feb 15, 2022 | 04:36 PM
Biggiesacks's Avatar
03 Evo = 94170015.
Old Feb 15, 2022 | 06:43 PM
kaj's Avatar
kaj
Judging by other posts I'm reading, that is a STEAL. I'd do that and be done with it.
I'm looking to have mine done since my tuner didn't save my immobilizer code. Bleh.
Old Feb 18, 2022 | 12:44 AM
03 Evo = 94170015.
thank you!
Old Feb 18, 2022 | 12:45 AM
Not when you look at the 06 Service bulletin and it says its a .3 warranty job. If its .3 there, I'd expect an hour or less to do the job.
Old Feb 19, 2022 | 12:16 AM
kaj's Avatar
kaj
That may be but people are posting insane dealership quotes.
JasonCX
15
Aug 11, 2016 12:00 PM
Xene
Jun 1, 2016 07:20 AM
tonerockyhorror
Sep 24, 2012 10:42 AM
Standing Z
Mar 22, 2009 01:04 PM
CHRISH5142
66
Aug 1, 2007 06:11 PM
