-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   280's Map (https://www.evolutionm.net/forums/ecu-flash/200535-280s-map.html)
Noogles May 11, 2006 10:14 AM
280's Map
Ok Guys i've been messing with the software a bit now and this is what i've come up with.
Mods are HKS RS Intake, Comp 280+, 3" BR Turbo Back, Buschur Race FMIC, AMS Hardpipes, Forge MBC set @ 23lbs tapering to 21.
MAke comments hack it up do as you wish.
*Note Idle Is a bit High But dead on, you can hardley tell the cams are there.
Noogles 280 Tune
b0ostedEV08 May 11, 2006 10:28 AM
That's good, glad to see you are learning how to use it... {thumbup}
MalibuJack May 11, 2006 10:41 AM
Similar to what I'm running right now.. I wonder how everything will work for me when I get the big injectors and big turbo done.
Noogles May 11, 2006 10:45 AM
thats the same thing i'm wondering i have 1000cc injectors, Methanol and a 35R on the way.
I'll let a Pro do the Initial tune for the 35r then i'll tweak it as i see fit.
Hey Malibu whats your timming table like. I Know mine is a bit low up top but i don't how much more i can push it on crap 91 octane.
MalibuJack May 11, 2006 10:53 AM
I am running stock fuel and timing tables right now since I still have the UTEC on my car (and don't plan to remove it any time soon) I'm waiting for some of the VE compensation tables and MAF-VE tables to get published before I do too much more since my MAF curve is slightly different than stock, plus I'd like to rescale the Maps before I do a full tune..
RazorLab May 11, 2006 11:02 AM
Nice Noogles,
Wasting no time! I'll take a look at it tonight or this weekend. I haven't had time to play with ECUFlash at all yet. Damn work! :(
Do you have cam gears and if yes, what are they set to?
Noogles May 11, 2006 11:14 AM
No Cam Gears they installed straigh up 0,0
Agent-Smith May 11, 2006 03:25 PM
Unless you have built internals and a valvetrain I would not have your rev limit that high!
Noogles May 11, 2006 03:27 PM
Valvetrain is taken care of and i've spoken to turbotrix many times about the reliability of the bottom end and they feel 8000 rpm is within it capabilities.
Agent-Smith May 11, 2006 04:03 PM
im showing 8.3k in the map i have?
Noogles May 11, 2006 05:04 PM
Thats right i'll shift at 8 but i don't want a hard limiter setup right at my shift point.
I wish we had the option of both a soft and a hard limiter. I would set the soft limit at 8050 and the hardlimit @ 8200
A418t81 May 11, 2006 05:09 PM
Nice man, I'm looking at my dynoflash setup and the hi/lo octane fuel/timing maps are the same. I'd like to setup the low octane maps again, but I need to find that article that shiv wrote a while ago about how the ecu floats between the two, etc.
Al any particular reason that its done this way?
MalibuJack May 11, 2006 05:32 PM
without going into too much detail, making both maps the same means the car won't drift into a lower power map. What you make of it depends on your needs...
05BlackEVO May 11, 2006 05:42 PM
i assume you have a fuel pump correct?
A418t81 May 11, 2006 05:43 PM
Well yeah, I know that ;) And I am looking for detail here :D It worked out well either way that this is the case as I used to worry what my Xede was doing when/if the ECU floated maps. Guess that concern was for nothing ;)
Do you know what the conditions/triggers are and the values needed to float maps?
