-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Car won't idle Evo9 Cosworth Cams (https://www.evolutionm.net/forums/ecu-flash/306178-car-wont-idle-evo9-cosworth-cams.html)
my04s2k Nov 6, 2007 07:57 PM
Ecuflash noob...need help
My car won't idle correctly with the AC on or off, it constantly goes up and down. I know i want to be using the 88590015 but i can't get it converted. i have attached a screen shot showing my current idle settings. i have searched and found the data needed regarding the cossie cams.... just can't convert to 015 file and get the scaling correct. any help would be great. my tuner is busy and can't get to it for a few days....
Ecuflash V1.33
Internal ID 88590013
my04s2k Nov 7, 2007 06:12 PM
i don't understand why the engine temp units don't go in some type of logical order. like going from colder engine high idle..... to warmer engine low idle. any help?....
Dapper Dan Nov 7, 2007 07:56 PM
advance your timing in the load cells where you idle.....
RazorLab Nov 8, 2007 12:17 AM
Use a older version of ecuflash, like 1.29 and they should show up correctly.
However 9's should idle just fine with cosworth cams without any rom mods. You sure something isn't wrong with the install?
All the cosworth 9 cams installed at the shop purr like kittens.
Oracle1 Nov 8, 2007 06:42 AM
Yes increase timing on idle IMHO 11-14 degrees. Also check fuel trims, might need to increase latency. Also make sure your mivec is not advanced during idle.
my04s2k Nov 8, 2007 11:29 AM
i could not find 1.29 so i got the new 1.34 and that fixed the scaling issue.
buschur installed my cams... so it was done correctly
can someone post the stock idle settings
thanks
Dapper Dan Nov 8, 2007 12:22 PM
thanks
i can email you 1.29 if you want it...
20psiMR Nov 8, 2007 01:50 PM
I keep trying the new versions that come out, and immediately go back to 1.29. And like Bryan said, my 9 with cosi's had no idle tweaks at all and purrs. Make sure you dont have advance between 0-30 load up to 1500 rpm in your mivec table. Adding timing in mivec will give you a lopey idle. Im running 5 degrees timing in my normal maps in the idle range.
my04s2k Nov 8, 2007 05:20 PM
ok changed that in VVT Map 1 main. the other timing maps High octane 1-3 and Low octane 1-3 have 5 degrees up to 1000rpm, 10 degrees at 1250rpm, 15 degrees at 1500rpm. so do i need to make them all 5 degrees in the idle range on all of those maps between 0-30 load or 0-40?
Thanks
Evo_Jay Nov 8, 2007 06:06 PM
I made a link to version 1.30 (newest one before it got weird) in this thread
https://www.evolutionm.net/forums/sh...d.php?t=305301
nj1266 Nov 8, 2007 11:50 PM
You can find all the versions you want here
http://www.openecu.org/index.php?tit...rev&oldid=1979
Just click on the older version arrow and you will get to 1.29a
Evo_Jay Nov 8, 2007 11:56 PM
Actually you get 1.30. But yeah, its there too.
20psiMR Nov 9, 2007 08:29 AM
1 Attachment(s)
Thanks
That looks ok...between 0-30 or 0-20 is more in the idle range. You could drop the 1250 but I would leave the 1500 alone. Either that or here is ss of my timing in the low range, if you want to copy that.
https://www.evolutionm.net/forums/at...1&d=1194625745
